Reducing Compression Ratio
31 replies to this topic
#31 diogoteix
diogoteix
  • 170 posts
  • Local Club: Mini Club Portugal
Posted 06 October 2011 - 10:14 AM
Today I will adjust everything and see if with a resonable correction for intake air temperature / water temp, all my problems of pinging get solved: I'm thinking of -2º advance at 40ºC, -4º at 50ºC and -6º at 60ºC, the maximum AIT I've read in my logs until now. I will also remove 2º advance at 90ºC water temp and -4º at 100ºC. So with a massively overheating engine (water at 100ºC and air intake at 60ºC) this would end up removing 10º advance. The car will be a cow but in a safe zone regarding pinging. That's the beauty of an ECU compared to a dizzy, quite useful when the summer comes in October (we will hit 31ºC today in Lisbon) and your stuck in trafic.
Diogo
So from reading the above, by the time it's got up to operating temperature you've removed 18 degrees of timing.........
Hopefully not! The figures do not add. With an engine running normaly, at 80ºc water temp and intake air temperature below 40ºc, there is no timing adjustment. You only start adding up above that:
For example with an intake air temp at 50ºC and water temp at 80º (hot day but engine cooling normally), timing is adjusted by 4º+0º=4º
with an intake air temp at 50ºC and water temp at 90º (hot day in traffic, engine struggling to cool), timing is adjusted by 4º+2º=6º
with an intake air temp at 60ºC and water temp at 100º (engine overheating, extreme conditions), timing is adjusted by 6º+4º=10º
Edited by diogoteix, 06 October 2011 - 10:14 AM.
#32 diogoteix
diogoteix
  • 170 posts
Posted 06 October 2011 - 10:21 AM
Here are the ignitions and injection corrections I just set for my ECU for adjustments related to water and air temperatures.
In some cases, I leave extreme temperatures with no adjustment to take into account possible sensor failure. If the sensor fails or is disconnected, the ECU will see a value of 0V coming from sensor which corresponds to the lowest reading possible. I'm not planning to bring my Mini to the North Pole so there is no way to get a water/air temp at -30ºC.
Edited by diogoteix, 06 October 2011 - 10:30 AM.
