Due a poor work done on my cylinder head, I'm currently having trouble with a compression ratio of about 12/12.5 (read on a compression meter). My calculations were supposed to lead to a ratio of about 11.0... I'm not sure if the mistake has been done by the people who cut the head or me (my guess, it's them, I'm in Portugal and quality of service is not something very common...).
Anyway, I need to reduce compression ratio to about 11, which means incresing cylinder head volume by about 3 to 4 cc. I see 2 options:
- 3 to 4cc corresponds to the volume of a head gasket. Do you think it's feasible to put 2 head gaskets or will I just end up with a leaking head? I've got a dry deck so water galeries are shut, but oil and air (between cylinders) might be an issue?
- Alternatively, I can have to head volume increased. It will be obviously more costly, and I'm not sure if it's easy to remove 3cc to a head. Despite being an old "SPI stage 3" from Minisport, the head volume seems to be standard (20 to 21 cc). Do the valve seats need to be reground or can the "meat" be taken around without disturbing to much the head chamber eficiency.
Thanks for your suggestions
Diogo
