How To Remove Paint From Here?
11 replies to this topic
#1 Swainy
Swainy
  • 319 posts
  • Local Club: Sexy People Only Mini Club
Posted 04 October 2011 - 12:34 PM
Hello!
Sorry if I have stolen your picture but...
How do you remove the paint from the area where I have indicated?
I can't sandblast or anything like that. I was just wondering if anyone knows how to do it.
I am currently using the discs on an angle grinder to strip down to bare metal but in the small nooks and crannies it won't fit.
Any help would be great :)
Thanks,
Adam
#2 davej
davej
    Kelly Jones
  • 985 posts
Posted 04 October 2011 - 12:50 PM
For the nooks and crannies I find it best to use some emry paper and elbow grease
#3 sam7
sam7
  • 165 posts
Posted 04 October 2011 - 01:34 PM
have you tried any paintstripper mate? mite be quite handy for tight gaps. does have its downfalls tho- dont let it dry over night because it goes hard again.
or a wire wheel on a drill is pretty good for removing paint
#4 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 04 October 2011 - 01:51 PM
Nitromores will get rid of it no problem but as the above dont let it dry out i used it on my aloy wheels did all 4 in a couple of hours
remove any rubber or plastic though
#5 Swainy
Swainy
  • 319 posts
Posted 04 October 2011 - 02:11 PM
I haven't tried anything. Thought I would ask on here before I start splashing the cash.
I've heard that paint stripper soaks into the metal and when you come to paint it it doesn't stick.
Is this true? If so how would I make sure it is all off.
#6 sam7
sam7
  • 165 posts
Posted 04 October 2011 - 02:31 PM
na never had any problems with it mate, i stripped all the paint from my mini with it the other day-and sprayed some old paint over the bare metal to stop it rusting till i get round to filling the dents. and it went on fine.
but you will need to rub it down after anyway so you shouldnt have any problems with the paint not sticking. just finking of it i did use a car paint stripper thats a bit harsher than nitromors and had no probs. just make sure you use goggles and cover your arms because it stings and burns properly!!
#7 Swainy
Swainy
  • 319 posts
Posted 04 October 2011 - 02:42 PM
Ah right nice one. What did you rub it down with?
#8 firefox
firefox
  • 1,102 posts
Posted 04 October 2011 - 02:54 PM
use 80 grit wet and dry nice and rough make your primer stick
#9 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 04 October 2011 - 03:17 PM
Its advised to neutralize the paint stripper before paint by using a scotch pad (green is fine) and clean it with thinners, this will neutralize the stripper and it wont strip new paint 1-2-3+ months own the line..
Dan
#10 sam7
sam7
  • 165 posts
Posted 04 October 2011 - 03:26 PM
just used an electric da with 80 or 120 grit paper. then if you want use some thinners will help clean it
#11 mike.
mike.
  • 6,176 posts
Posted 04 October 2011 - 05:45 PM
Wire brush attachments work ok on drill and grinders but can be hard work to get down to bare metal sometimes.
These paint removal discs work really well if you can get at the areas. You can get drill mounted ones too:
http://www.ebay.co.u...6.c0.m270.l1313
#12 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 04 October 2011 - 06:04 PM
key the paint with 40 grip paper . get it real scratch up ... put paint stripper on it nice thick coat ... then get a big sheet of thin shopping bag plastic . place it tight over the whole area stripped .
. plastic helps the stripper sweat and is more efficent ..... grinding it you are just going to scratch up the metal then you will have to put heaps of primer on it to hide all the scratched areas
