Alex's 1982 Hle Rebuild
780 replies to this topic
#91 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 05 June 2012 - 09:14 PM
Did a bit more today, I kurusted the shock mount and painted it,
I also wire brushed the drivers floor as since we mad the reapairs Surface rust had come through.
Where I found a small hole.
Tommorow i should be welding and grinding the floor and up the flitch so I can repaint it.
Comments welcome
Alex
#92 minimuk
minimuk
  • 1,946 posts
Posted 05 June 2012 - 10:11 PM
Comments welcome
Alex
Alex hi, doing well,but would you not rather replace the front floor panel as this one is rather pitted....
#93 alex-95
alex-95
  • 6,025 posts
Posted 07 June 2012 - 03:19 PM
I'm satisfied with it, I tested a small weld on the pitted area and didn't burn holes :proud:
Yesterday I Welded up the small hole in the floor and ground that back.
I also ground back the welds to the inside, It still needs a bit of work done.
Alex
#94 minimuk
minimuk
  • 1,946 posts
Posted 07 June 2012 - 03:58 PM
all good then, doing well!!
#95 alex-95
alex-95
  • 6,025 posts
Posted 07 June 2012 - 04:16 PM
Cheer's minimuk :-)
#96 minimanryan
minimanryan
    Just On Tickover
  • 7 posts
  • Local Club: crewes missiles
Posted 08 June 2012 - 01:15 PM
very nice how you get the little mini at the bottom of your posts alex-95 i want a estate version
#97 alex-95
alex-95
  • 6,025 posts
Posted 08 June 2012 - 02:38 PM
Thanks, It's on this website http://www.miniselecta.com/ then you can crop it and upload it to photobucket and copy and paste the IMG code into your signiture.
Have you got a build thread of your clubby estate?
#98 alex-95
alex-95
  • 6,025 posts
Posted 11 June 2012 - 07:43 PM
I had another half a day in the garage which consisted of grinding, painting, grinding, welding and a bit more grinding.
Firstly I ground down the welds on the shock mount area. I also had to enlarge the bottom holes for where the bolts go as they were scraping against it, I also retapped the holes as the bolts were a bit stiff.
Then I painted it
Then I ground down more of the welds down the inside flitch, and welded a few places then ground back.
Alex
#99 minimuk
minimuk
  • 1,946 posts
Posted 11 June 2012 - 08:05 PM
I am sure you know but treat the cleaned surfaces asap before the virus returns......
#100 alex-95
alex-95
  • 6,025 posts
Posted 11 June 2012 - 08:13 PM
That's tommorrows job :genius:
#101 alex-95
alex-95
  • 6,025 posts
Posted 12 June 2012 - 07:16 PM
I found some rust between the floor and the cross member, So i split them, wire brushed, Kurusted and welded,
Then I gave it a coat of Hammerite.
I also Cut the support on the rear bin And started making a new piece.
Posted ImagePosted Image
Alex
#102 minimuk
minimuk
  • 1,946 posts
Posted 12 June 2012 - 07:54 PM
Nice one, inching on,.....just don't cut yrself in them tight corners... ;D
#103 alex-95
alex-95
  • 6,025 posts
Posted 12 June 2012 - 08:00 PM
Thanks, Already have :lol:
#104 alex-95
alex-95
  • 6,025 posts
Posted 16 June 2012 - 05:37 PM
Today I had a bit of time in the garage, so I cracked on.
I Measured the distance between the subframe hole's and got them right and clamped a peice of metal From the subframe mount to the heelboard so it didn't move, then I welded in the strengthener from the bin to the subframe mount.
Then I welded on the 2 strengthers on the subrame mount.
Comment's Welcome
Alex
#105 grahama
grahama
  • 2,442 posts
Posted 16 June 2012 - 07:48 PM
All looking pretty good to me Alex. Nice strong repairs, not sure about the poo coloured paint used inside tho lol. Might just be the pic !! Keep going!
Graham
