Alex's 1982 Hle Rebuild
780 replies to this topic
#76 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 25 April 2012 - 04:03 PM
Yeah, I sprayed some primer on it and will probably put some hammerite on it. :-)
Edited by alex-95, 29 April 2012 - 07:01 PM.
#77 alex-95
alex-95
  • 6,025 posts
Posted 29 April 2012 - 07:07 PM
Yesterday we got some welding and grinding done.
We welded on the subframe mounting plates that i made a while ago on to the passengers side and ground that down. I just need to drill the hole's.
Dad ground down the boot repair at the back and rewelded in a few places.
I ground down the seam patch and sprayed on some primer.
Comments welcome
Alex
#78 alex-95
alex-95
  • 6,025 posts
Posted 05 May 2012 - 08:22 PM
Todays update.
We cut out the rust around the quarter panel.
Cut out the rust in the bottom of the bin.
Any comments Wecome.
Alex
#79 alex-95
alex-95
  • 6,025 posts
Posted 12 May 2012 - 07:51 PM
Today we replaced Lulu85Ritz's apanel :-)
#80 alex-95
alex-95
  • 6,025 posts
Posted 20 May 2012 - 07:13 PM
This weekend we made a few patches for the rear bin and started to weld them in.
I drilled off the old Strengthener and made a new one ready to be welded.
Made a repair panel for the inside bin and welded.
Then made a pepair to the end of the bin.
I also started making a panel for the sill
Alex
#81 alex-95
alex-95
  • 6,025 posts
Posted 22 May 2012 - 04:55 PM
Any comments? :gimme:
#82 minimuk
minimuk
  • 1,946 posts
Posted 22 May 2012 - 05:07 PM
Alex, will you weld a nut for a 5/16 on the inside of the heal panel, to bolt on the upper nearside trunion? Before you close up the sill,....
#83 alex-95
alex-95
  • 6,025 posts
Posted 22 May 2012 - 05:10 PM
Kind of, I'm going to take off the other bolt then I'm going to tap 1/2 inch steel with both holes on so it will be stronger.
#84 minimuk
minimuk
  • 1,946 posts
Posted 22 May 2012 - 05:20 PM
that's a plan....
#85 alex-95
alex-95
  • 6,025 posts
Posted 22 May 2012 - 05:36 PM
It is :D
#86 alex-95
alex-95
  • 6,025 posts
Posted 25 May 2012 - 09:04 PM
Did a bit of work tonight, I drilled and tapped the 1/2 inch steel for the subframe mounts, It just needs cutting and welding on.
Tapped
Alex
#87 minimuk
minimuk
  • 1,946 posts
Posted 25 May 2012 - 09:15 PM
looks good, great idea,...well done, hope you gave yourself enough space to put it in it's final position......
#88 alex-95
alex-95
  • 6,025 posts
Posted 26 May 2012 - 09:02 PM
Today Me and dad cut and welded the subframe mountinf bolt,
We cut off the old bolt and the rusty metal aswell
We then welded it on after measuring.
I cut out a repair for the front shock mount out of 2.5 mm steel.
Alex
#89 alex-95
alex-95
  • 6,025 posts
Posted 27 May 2012 - 07:49 PM
Did a bit more today. Pianted the shock mount and welded that on.
I also made a strengthener for the subframe mounts ready to be welded on.
Alex
#90 alex-95
alex-95
  • 6,025 posts
Posted 27 May 2012 - 07:51 PM
Also my gearstick knob :D
