Alex's 1982 Hle Rebuild
785 replies to this topic
#556 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 23 August 2017 - 08:20 PM
Looks really really good man, sooo lovely and clean  :thumbsup: Will the mirrors be going body colour?
the only problem being that it was too low
I see no problem here  :P
Cheers mate, yeah body colour, when I pull my finger out. it's just a pain getting all the painting stuff set up just for them, I may as well spray the MPI's bonnet at the same time :rolleyes:
Hahaha, I would love it to be low like yours but it's not very drivable. I could make the shocks a little harder...
#557 alex-95
alex-95
  • 6,078 posts
Posted 10 September 2017 - 07:37 PM
I don't think I put these photos on here but heres my boot board and light.
My steering lock never worked so thought I should do something about it, after trying a bit of lubricant and it still not working. I ended up buying a new one with the metal barrel surround like the original but turned up and was a plastic type >_<, so another search around as most places have the plastic type now. but finally found one and arrived yesterday. the quality was better than the plastic one and I could insert the key and pull it out fairly easily unlike the plastic one. I fitted it today and tightened up the bolts and like most other parts you can buy these days it didn't fit :thumbsup:  :w00t:. After taking some measurements you can clearly see why, the steering column is 28.5mm (or near to it.)
the top one is the "metal" one, the middle is the original and you guessed it the bottom is the plastic one.
A is the diameter between the 2 splits and B is the diameter on the ignition half. Between the original and the "metal" one there is 1.1mm so the 2 half clamp up before it clamps the column. I'm not sure if the original later plastic type ones were the same shape and sizes as the above.
RFQg98W.jpg?1
I've also started doing bits on the engine build, I've had the con-rods and pistons balanced and am going to get the crank, flywheel and pulley done as well after milling slots into it for the mega jolt. The flywheel had been bashed at some point to try and remove it, so i've skimmed it and put the chamfer back on. I've also machined the primary gear bushes.
Not bad...
#558 alex-95
alex-95
  • 6,078 posts
Posted 11 September 2017 - 07:55 PM
running pretty true
#559 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 11 September 2017 - 08:02 PM
running pretty true
Looking good, did you check there was no run out on the dial gauge on the inner bush when it was still in the lathe, i.e. the two bushes are parallel?
#560 alex-95
alex-95
  • 6,078 posts
Posted 11 September 2017 - 09:17 PM
running pretty true
I bored the jaws so what I was holding should be parallel and bored both bushes at the same time. I put it on the crank when I finished with DTI and was good :thumbsup:
#561 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 11 September 2017 - 09:35 PM
running pretty true
Very impressed, its good to see nice work :proud:
#562 alex-95
alex-95
  • 6,078 posts
Posted 22 September 2017 - 08:12 PM
Sorted out my trigger wheel/pulley today, I do have a 'trigger wheels' one but I think it's best to machine the pulley. so I've taken that up to the engine balancer.
Had the "teeth" CNC'd on this fixture, so the key way inline with the missing tooth.
Then I put it on the lathe and removed some of the meat so that the sensor constantly sense the steel.
#563 alex-95
alex-95
  • 6,078 posts
Posted 26 September 2017 - 07:42 PM
:gimme: Apart from dropping one on the second coat of paint (luckily it didn't break the glass, just a couple of digs) spraying the mirrors went quite well :lol:
#564 alex-95
alex-95
  • 6,078 posts
Posted 06 October 2017 - 08:25 PM
Made it to castle combe last weekend with no problems :gimme:
22219922_1790303974344784_59204904836916
22256793_1790304097678105_24832992657090
Edited by alex-95, 06 October 2017 - 08:26 PM.
#565 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 06 October 2017 - 09:02 PM
Looking great buddy! Should be proud of your work :thumbsup:
#566 alex-95
alex-95
  • 6,078 posts
Posted 07 October 2017 - 07:48 PM
cheers mate.  :D
#567 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 08 October 2017 - 06:14 PM
Looking good Alex. Nice to see it on proper wheels :-)
I was hoping to make Castle Comb but I had my Grand Children for the weekend in Plymouth.
#568 alex-95
alex-95
  • 6,078 posts
Posted 08 October 2017 - 06:24 PM
Thanks Mate, yeah much better than the 12's.
yeah was a good show, should have brought them with you :lol:
#569 alex-95
alex-95
  • 6,078 posts
Posted 24 November 2017 - 09:14 PM
I Haven't driven it for a while as the weathers not been great, I've done a few things to it and done a bit to the 1293.
I booked up the MOT yesterday for the Mot today. to make it easier when I get the 1293 in, so Had to check it this morning, had to fix the rear passenger indicator, numberplate light and then it nearly didn't start like last year ... I don't think it likes MOT's ...
it passed though!!! :gimme:
Edited by alex-95, 24 November 2017 - 10:24 PM.
#570 Steve8274
Steve8274
  • 580 posts
Posted 24 November 2017 - 09:58 PM
Car looks great. Can I ask where you got fog and reverse lights from?
Good luck with Mot
