Alex's 1982 Hle Rebuild
785 replies to this topic
#541 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 14 June 2017 - 08:06 PM
We've taken it apart and the list of things to repair it at the minute is:
1 x tyre for the ritz's wheel
2 x bearings (going to do both sides)
1 x left hand nut (may have one though)
1 x washer (may have one)
1 x rear hub
1 x radius arm!!!!!!!!!!!!!!!! :xxx:
1 x radius arm bush kit
So it's a lot worse than it looks/expected, the pin the bearings sits on is damaged as is the hub. I would have just pushed the pin out and put a new one in but the radius arm has a little crack either when the bearings have got really hot and caused the pin the expand and crack the casting or where it locked up all of a sudden and pulled the pin. :crazy:
#542 pete l
pete l
  • 1,539 posts
Posted 15 June 2017 - 08:50 AM
Was there any warning noises with regards to the rear wheel bearing ?
#543 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 20 June 2017 - 03:50 PM
oh man! She was looking lovely from the pictures I saw, I like those metro turbo wheels alot! Quite a bit of damage though  :ohno:
#544 alex-95
alex-95
  • 6,078 posts
Posted 20 June 2017 - 04:54 PM
Nothing I could hear that sounded like the bearing >_<
It's looking alright ;D, They're similar to the metro wheels but they're from the ritz (as it's off the road and getting lighter by the day from the amount of rust :lol:) but it does look quite good on them ... surprisingly. Yeah a fair bit but could have been a lot worse. I don't think it wants to get back on the road though, I bought a set of arms but the passenger one was knackered  >_< , So I've currently got 4 spare drivers radius arms and no good passengers :w00t:
loved these sprints
2 moke tubs in the back of a van, they were german and came over with a trailer but unfortunately they had an accident with it so had to hire a van. it was millimetres of space to get them in.
This car was right up my ass on the way home  :lol:
#545 alex-95
alex-95
  • 6,078 posts
Posted 25 June 2017 - 07:43 PM
I finally managed to get a passengers radius arm so am cleaning it up at the minute.
Oh yeah I was in miniworld.
BE96D5A4-9F28-4738-9216-488D90B2DCD9_zps
#546 alex-95
alex-95
  • 6,078 posts
Posted 09 July 2017 - 09:20 PM
You'll just have to imagine the previous photos...   ... I'll try and swap them over at some stage if it doesn't sort it's self out.
Anyway, with a passenger side radius arm acquired I cleaned it all off and ground some of the casting marks out to make it smooth like the other one. Gave it a coat of zinc paint, fitted the bush and reamed it and fitted the nylon sleeve and needle bearing.
Then gave it 3 coats of black as well as a spare hub I had and pushed the wheel studs into it.
I removed the drivers hub because I didn't trust the bearings and it was right to do so as it was starting to go as well!!! So I removed the 'OLD' bearings and pressed in the timken's. It was then just a case of fitting it all back together. It was very easy to get the old radius arm off ... NOT...   :lol: Because I fitted the protect shortened shocks the radius arm would not move down low enough to remove it and with a bur stopping the pin coming out the subframe made the job a right pain as I had to cut the pin that shocks slides onto and try wrestling with it trying not to scratch the paint. Then it was just a case of refitting, changing back to the 10's and checking the front wheel bearings which they seem OK, but will be changed for timken's. I think the problem with the non genuine bearings was that they were too short so added the preload on them.
And gave it a wash :wub:
#547 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 10 July 2017 - 06:50 AM
Those last photos :wub: , looks spot on on 10's!
#548 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 10 July 2017 - 04:29 PM
That last photo is stunning!!
#549 alex-95
alex-95
  • 6,078 posts
Posted 11 July 2017 - 08:10 PM
Thanks guys, I want to get My ATS classic refurbished to stick on :gimme:.
I'm currently in the middle of painting another set of mirrors body colour which I'm hoping will be ready to fit on saturday.
#550 Mervyn
Mervyn
  • 256 posts
Posted 12 July 2017 - 05:23 PM
What a charming looking mini, credit to you
Merv
#551 Twilton
Twilton
  • 57 posts
Posted 12 July 2017 - 06:15 PM
Looks mint!
#552 minimans
minimans
  • 411 posts
Posted 12 July 2017 - 10:52 PM
Great looking car! colour really suits a mini. I'm still looking for a Castro R30/40 can like yours for the same purpose! If anybody has one Please let me know.........
#553 Haygate
Haygate
  • 115 posts
Posted 13 July 2017 - 09:04 PM
That looks great.
#554 alex-95
alex-95
  • 6,078 posts
Posted 22 August 2017 - 08:27 PM
Merv
Looks mint!
That looks great.
Thanks Guy's.
Haven't really done much on it or driven it really, there's still loads to do on the ritz and this one and the MPI >_<. We went to a car show a couple of weeks back, it drove for a clapped out 998, the only problem being that it was too low which ended up the passenger rear tyre ripping the chrome strip off the side (that corner is causing me problems :lol:) I've still got to paint the mirrors, maybe in time for castle combe? anyway photos.
#555 Will16
Will16
  • 1,090 posts
Posted 23 August 2017 - 07:38 PM
Looks really really good man, sooo lovely and clean  :thumbsup: Will the mirrors be going body colour?
I see no problem here  :P
    Bing (1)
