Alex's 1982 Hle Rebuild
780 replies to this topic
#481 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 17 July 2016 - 09:19 PM
Nice!!
Oh and what a tidy garage :-)
Thanks mate, lot's to do still though. pretty much got everything to put it back together, just need another windscreen and a headliner.
You don't know whats behind the photograph :lol:
#482 lulu85ritz
lulu85ritz
  • 1,308 posts
Posted 18 July 2016 - 10:48 AM
Might I just say WOW well done to you and your dad that is smashing! it's crazy how far this as come since the last time I saw it in the flesh, you will be on the road in no time.
#483 lulu85ritz
lulu85ritz
  • 1,308 posts
Posted 18 July 2016 - 10:49 AM
I should really change my name, profile pic and banner for here lol.
#484 alex-95
alex-95
  • 6,025 posts
Posted 13 September 2016 - 08:45 PM
So time for an update, didn't make MITP and castle combe is in 4 days time... so It's going to be ready before christmas      (unsure what year... :lol: )
​So as you can see I got it all rolling and got some dolly's to put it on, which make moving it around hell of a lot easier.
Got the bits back from the powder coater.
Cleaned some bits and painted it.
got some more bit's from DSN :gimme:
Made a few bits:
switch bracket for the fog light and brake test light since I have no room on the mk1 switch panel.
DD603E9A-501B-49B5-BDAF-2B1FF8158C0C_zps
Some caps to cover the tower bolts.
111CF9CE-8474-400A-86B2-B2005B07A96C_zps
Some stainless mk1 light screws and dividers. The screws are made from 3/16 stainless with 4BA thread and tapped M4 and then a M4 screw glued in, the head of the M4 screw is pretty much the same dim's as the originals.
83EFF339-83CF-455E-BAB9-AC7672805E26_zps
some grease nipple covers
4224911E-E203-4B2F-949C-37A0D96BBCB6_zps
and done some wiring, indicators, fog light and reverse light, lots of other bits, in the pic below : added 2 more lights into the centre binnacle loom for the oil light and rear screen and part of what I need to make my hazard switch work as I'm not using a rocker switch.
D5E6A9E0-88B3-471F-9C6B-D4DC243AD50A_zps
installed my tank but have a gap between the tank and seal, think I'll get a MPI seal as they're thinner.
8D8C1766-996C-4E63-8267-BFD9168233E3_zps
Got an MPI interior
A008E634-882D-4BC8-88DA-3215132B8B6E_zps
And got some silent coat stuck in
BE9BC874-BC2C-41C1-A75F-8B759BE58918_zps
4B9AC4CC-DB25-43D4-8C19-602E2066D405_zps
6E8689D0-542A-4108-9EAD-4E6C93F8AC18_zps
#485 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 17 September 2016 - 07:39 PM
Great work as ever Alex and what finite detail, wish I could have done  mine to the same level :-)
Nice colour too.
#486 alex-95
alex-95
  • 6,025 posts
Posted 20 September 2016 - 08:49 PM
Nice colour too.
Cheers mate, it's good to go into detail but takes so much  more time and money  >_<
Didn't get much done this weekend as we went up to castle combe and bought a few bit's, an MPI fuel tank seal, some NOS door mirrors that need spraying and a 998 clutch.
so I got the tank fitted which needed a bit of fettling.
27EB5A40-70E5-405F-90EE-1D0B7A1F1DF2_zps
I made some fog and reverse light brackets a while ago to.
1E2FEA7F-10B7-40E5-887C-814AEEDCDBC8_zps
and the past couple of evenings have been fitting more silent coat, nearly used up the 40 sheets...
D6241BF8-F300-4183-A795-D72D35CD9560_zps
9A87A197-2DE2-4FBD-AAF9-39D65D660D3A_zps
3AD65F0F-693B-4E82-A731-79321B827362_zps
229534F1-92F1-4F8C-86B5-CF872778C1CB_zps
#487 alex-95
alex-95
  • 6,025 posts
Posted 23 September 2016 - 08:58 PM
I cleaned and painted the engine a while back and while I was there removed the wok to see whats it was like inside, of which it was covered in oil. So one evening I got the engine out and removed the flywheel and clutch with my Heavy Duty "Gerrof ya b'stard" Flywheel Puller from guess works but had no way of removing the seal, so dad got some 65mm ID tube cut it up and made the bolt end for it out of 6mm plate and the other a U shape with a ~48mm ID to match the gear groove and I welded together and drilled and tapped it M12. which got us something similar to the standard tool, used an old main bolt and drilled it a little to centre the tool bolt. and gave it a lick of paint
7F76C6DF-A5E9-429C-87BD-71DAE5A44D73_zps
599D25D0-9A96-4B07-AD89-6A8D6A870BC6_zps
B5D5B784-BE8F-4BDB-9DE6-CDAF439D3342_zps
404F7E37-FAF2-42F6-B9A9-27965B413FB3_zps
Edited by alex-95, 23 September 2016 - 09:01 PM.
#488 minimuk
minimuk
  • 1,946 posts
Posted 05 October 2016 - 11:19 PM
Looking good, precision work,practice is paying of, well done Alex...and Dad
#489 Chris1992
Chris1992
  • 2,022 posts
Posted 06 October 2016 - 10:50 AM
Looks sweet mate! Love the colour of the brake/clutch cylinders. Goes really well with the copper pipes and the colour of the car!  :thumbsup:
#490 alex-95
alex-95
  • 6,025 posts
Posted 06 October 2016 - 09:25 PM
Thanks, was good to finally meet you at MITP. certainly is, slowly getting there.
Cheers mate, me too :lol:, different to the normal silver. :gimme:
I've (sometimes we've) been doing some bits and bobs, the shell is pretty much polished, just need to do the doors and bonnet, some wiring, buying and other bit's and bobs. got a crank oil seal tool so fitted that and also the clutch and flywheel etc.
Tonight we stuck up the felt sound deadening that I got from http://www.woolies-trim.co.uk, the roof doesn't 'ding' much now, which I'm glad of since it has 8 sheets of silent coat and the felt as well.
277EF310-B815-4C35-8F35-BAF9A4EC1BBB_zps
and made the second stainless bit for the later type heater, I'm making new pipe bit's too out of stainless, the old ones are like a sieve.
665F76A5-7802-48D4-B22C-8DE874A7CD76_zps
#491 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 06 October 2016 - 11:23 PM
Just read this, awesome standard of work going in to it! Huge fam of the colour and the coloured coded tank caps :-)
#492 alex-95
alex-95
  • 6,025 posts
Posted 09 October 2016 - 07:14 PM
Thanks Will, I what to fit the early style one I sprayed but isn't a locking one ... yet...
few pictures I found I done back along.
I fitted the door striker plate things that I got from smiffy bits at MITP (as seen in some photos above.) but had to file one out.
cleaned/refurbed the heater, but needs a bit of modifying to get to fit right as I  haven't got the padded dash rails so it sticks out a mile.
When fitting the petrol tank remember to bend the little metal tags to hold wires in else you can't fit the tank very well and end up with this on the nicely painted tank (luckily you can't see it when fitted)  :whistling:
engine bay polished
Friday I did a few odds and sods, tightened up all the brake pipes, fitted the water pump to the engine and connected the fuel pipe.
And yesterday and today we were sorting out the headliner, I want to have a third level brake light for a bit of added safety so run 2 cables up the middle of the rear screen and with some calculations from the RITZ's brake light I drilled 3 holes, 1 in the middle for the wires and 2 for mounting it. then we hung the headliner and with many bulldog clips clipped it up and stuck it up. Easy as that .... ... .. .  :lol:  :lol:  :lol:  :lol: I still need to do around the rear window, top and bottom and stick it along the outside edges and cut it out properly. I now know why there are professionals that do  :lol:.
The pictures make it look better than it is, but for my first time doing it I don't think it's that bad.
Hopefully I will get it all finished during the week then should be able to get some glass fitted next weekend maybe.
#493 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 09 October 2016 - 07:29 PM
I remember doing the headlining in my car (also my first time). Took me three weeks of stretching it out before I glued it in for good. Looking good  =]
#494 alex-95
alex-95
  • 6,025 posts
Posted 09 October 2016 - 09:38 PM
Yeah it's a pain to get it stretched out, then trying to get rid of a crease, which another one forms because it's moved :lol:.
#495 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 10 October 2016 - 05:38 PM
I feel the pain of the creasing - still have one small one on mine that I couldn't get rid of  :lol:
