Alex's 1982 Hle Rebuild
780 replies to this topic
#406 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 18 February 2015 - 09:33 PM
So last weekend I got the rear arch welded in and all cleaned off as well as cleaning off the battery box,Which  I'll paint that tomorrow.
Then I started wire brushing the drivers side inner wing and the cross member which needed a re-repair as we made a repair near the start of the resto which was terrible so spent a while cutting it (you can kind of see it on the bottom corner.
which turned into this. I've made so cardboard templates ready for this weekend.
In some of the evenings I started cleaning off the rear subframe. Which I gave up on and sent it for sand blasting today which I'll get back tomorrow and paint it before the rust starts.
http://s1127.photobu...t]=1&sort=1&o=1
I've also been buying a few bit's, This grille muff, I caught the DSN bug so have bought a couple of their bit's, stainless p clips for the brake and fuel lines, and finally a sandblasting cabinet which will make cleaning parts a lot easier.
And I've owned it for 5 years today O_O
#407 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 21 February 2015 - 08:52 PM
Great stuff
#408 alex-95
alex-95
  • 6,025 posts
Posted 22 February 2015 - 09:32 PM
This weekend I reapaired the bulkhead bit.
fully welded in and the curved tapped around and welded along the edge.
And all ground down, much better than the other repair. just needs one spot weld doing on the lip that folds over.
and painted the rear arch and battery box.
The front subframe didn't get sand blasted so that a job to do during the week if it turns up. I also started cleaning up the inner wing and bulkhead.
#409 alex-95
alex-95
  • 6,025 posts
Posted 01 March 2015 - 07:47 PM
So I got my subframe back from sandblasting so first welded the top mounts and then gave it a coat of zinc spray . Then gave it a coat of the high build brush on zinc paint and now it’s got 2 coats of black on it which I’ll rub down and repaint, if it’s not a great finish I’ll rub it down again and spray it. Other than that I’ve been wire brushing the driver’s inner wing and bulkhead, and started making  a bracket to hold my oil can.
so much nicer welding the thicker metal.
brush on zinc paint and also sealed the seams with seam sealer.
bulkhead partially cleaned
and my oil cans.
#410 Mini_Matt
Mini_Matt
  • 96 posts
Posted 01 March 2015 - 11:08 PM
Where are you putting the oil cans?
#411 alex-95
alex-95
  • 6,025 posts
Posted 16 March 2015 - 08:42 PM
On the mini ;D
I've been trying out the sandblaster in the evenings, much easier than wirebrushing.
The the weekend before last I finished cleaning the inner wing, and bulkhead and zinc sprayed them, I also had to do a few bits of welding.
Then I tested the seam sealer, seeing how well it went on and when it goes off. masked it up, squirted it on and smoothed it out.
Then friday I spent the day masking up the whole underside, used 1 1/2 rolls of masking tape :ohno:
Then the "fun" began, I manged to borrow a air sealant gun rather than the hand pump type, I would recommend one if you're doing it, so much easier and quicker I think I would still be doing it next month else. With tips from "bigjay" of using a wet finger and pulling the masking tape off straight after. I started at the front and worked my way back.
I then had to do this to be able to the valance behind the wheel well,
And thats about it, Next weekend I'll hoefully be able to stone chip the majority of the underside.
#412 minimuk
minimuk
  • 1,946 posts
Posted 16 March 2015 - 08:49 PM
looking very professional there Alex, some great work you are showing us, well done, nearly there ;D
#413 Wufo
Wufo
  • 32 posts
Posted 16 March 2015 - 08:52 PM
What was the masking tape for?
#414 alex-95
alex-95
  • 6,025 posts
Posted 16 March 2015 - 08:57 PM
cheers bud, doesn't look bad close up either ;D :genius:. Need to crack of assembling the front and rear subframes to get it rolling when it's flipped over.
For making neat lines and corners, just make it look nicer, not that it'll matter when it's undersealed.
#415 alex-95
alex-95
  • 6,025 posts
Posted 29 March 2015 - 07:44 PM
The week before last I managed to get into the garage in the evenings to sandblast and paint a couple of parts.
then last weekend I started masking up for underseal but didn't manage to finish in time to spray it. I finished masking it up on friday.
I then started stripping and cleaning off the hubs. I filed the round part as I've heard the 8.4 to 7.5 conversion can rub on it, then tested them out which there was no rubbing :thumbsup:
Which went well until I spotted one of the threads had been stripped :(. Not sure to get another one or just helicoil it?
Then the time came to start spraying the underseal which was easier than I thought.
But as usual didn't go without a hiccup, I got a bit of a reaction in places.
A-panel to wing join
A bit here
And the worst, the rear valance which had red oxide on  >_<
Which now looks like this
So next weekend I'll have to re seam sealer it and the re underseal :(, Was hoping to be able to spray colour next week or the week after.
#416 StefanPieter
StefanPieter
  • 131 posts
  • Local Club: FDMC
Posted 31 March 2015 - 06:33 AM
It's is a great build. Love the detailed posts and pics.
The above post you talk about a reaction with the underseal. Why would it react? How do you prevent it?
#417 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 31 March 2015 - 04:48 PM
Its a reaction between 2 or multiple types of paint/coating not being compatible. The red oxide use now-a-days is common for doing it and hammerite will do it if you coat over it with anything other than hammerite itself. If in doubt. Do a test piece first and make sure one product is dry before applying another and follow manufacturers guidelines.
#418 alex-95
alex-95
  • 6,025 posts
Posted 31 March 2015 - 08:20 PM
Cheers mate. As above, just the paint doesn't like eachother :lol:, I've not had a reaction with hammerite but it has been on the car for a while which I think I've read helps. A test piece does help but it doesn't always react straight away, I'm going to spray some underseal onto a bit of metal and spray over it with cellulose to make sure it doesn't react.
I've been into the garage this evening and yesterday evening, zinc sprayed the rear valance and tonight seam sealed it again, not easy without the air gun. >_<
#419 alex-95
alex-95
  • 6,025 posts
Posted 10 May 2015 - 08:30 PM
A few things have happened in the last month, Re-undersealed the rear valance which it reacted with the seam sealer again, so have re-seam sealed it again ready for primer and colour. I've sorted out all the bits that I've got so I know where to find it and what I need to get. I removed all of the paint off the rear subframe that I did a couple of years ago O_O as there was rust coming through. so wire brushed it and painted with the brush on zinc paint and am giving it a few coats of the black.
I've been cleaning up more of the suspension bits.
sandblasted
Removed the paint off the radius arms and got the grinder on them to make them a bit smoother, removing the casting marks and numbers.
Here's the pin that was in one of the arms ... A tad worn
Found a good way of sealing the radius arms for sandblasting with a couple of rubber bungs.
And last weekend we went to riviera run and picked up a couple of bits including another set of wheels. Can anyone guess what they are?
Thats about it, next weekend we'l hopefully be making the full and brake lines so that I can drill the holes in the floor for P clips.
Alex
#420 Hendred
Hendred
  • 484 posts
Posted 11 May 2015 - 07:14 AM
What wheels are they?
