Alex's 1982 Hle Rebuild
780 replies to this topic
#301 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 14 June 2013 - 07:37 PM
Well it's been a while since I really did anything to him due to having to weld the Ritz for it's MOT and a few other things, But work should be starting again this weekend :gimme:.
A couple of things that I've bought:
And I finally got me a GB badge :D .
And as you can see it will need repainting as the black is permanent marker pen >_<. And will fill the holes and drill them again.
Should have a proper update this weekend.
ALex
#302 Minidarren83
Minidarren83
  • 1,207 posts
Posted 14 June 2013 - 08:32 PM
good to see you getting back at it alex
#303 alex-95
alex-95
  • 6,025 posts
Posted 16 June 2013 - 07:50 PM
An update :whistling:, saturday I did nothing to it as I had to do and oil and oil filter change, today I cleaned out most of the rubbish inside it, as it turned into a storage space and that's it :shy:.
Hopefully I can actually do some proper work to it next week.
#304 alex-95
alex-95
  • 6,025 posts
Posted 07 July 2013 - 09:25 PM
Ok a bit of an update. bought an austin mk1 grille and inno surround (already had the mk1 moustache)
I had two half days this weekend so Yesterday I set about repairing the wing.
Cut out and welded in a new peice on the front
I first cut off the scuttle end on the mounting lip and welded in a new peice then today i cut out the rectangle peice that needed replacing and welded in a new bit
Cut off the scuttle curve and cut a new peice which had curved to pretty much the right shape from cutting it.
Welded it on a spot at a time and cooled it down with a wet rag to prevent warping, and ground it down a bit.
I made this template before cutting out the rust so I know where the curve needs to go.
Thats about it for this weekend but hopefully will be able to finish most of it off on friday.
Alex
#305 zony
zony
  • 165 posts
  • Local Club: Welsh Rarebit Mini Club
Posted 07 July 2013 - 11:14 PM
I'm very impressed with your determination. Good work. Keep it up.
#306 alex-95
alex-95
  • 6,025 posts
Posted 08 July 2013 - 08:32 PM
Thanks Zony, I did do a bit of work today, grinding down th welds and cut the curve, I am not going to finish it just yet as it is difficult to get the curve right so we are going to weld the scuttle on and weld on the lip after.
Alex
#307 zony
zony
  • 165 posts
Posted 08 July 2013 - 09:29 PM
I don't have those skills, going to buy proper panels when I do mine. That's serious fettling with a capital F what you do.
#308 alex-95
alex-95
  • 6,025 posts
Posted 08 July 2013 - 09:49 PM
Fair enough, it just needs practice, a bit of time, it's pretty much just copying what has been cut out unless it's rusted away :lol:, I probably will wish that I bought new ones but it's cheaper this way and a lot more satisfying ;D. :D
#309 alex-95
alex-95
  • 6,025 posts
Posted 04 August 2013 - 08:03 PM
Another month gone past O_O.
We managed to get some work done on it yesterday, well mainly dad, I was just Holding the extraction fan a putting out flames :lol:
Dad wire brushed along the sill and all around the floor pan ready for welding (just the floor).
Pretty good for upside down welding, It just need's gring down and welding in a couple of spots where theres missed places.
Hopefully there will be more next weekend.
Alex
#310 alex-95
alex-95
  • 6,025 posts
Posted 09 August 2013 - 07:33 PM
I've a  bit more work over the past couple of days finally got the mk1 conversion panels off, did some wirebrushing and a bit of welding.
Wire brushed the door post and gave it a coat of kurust and primer.
fe990edd-55d5-4f7f-b4a1-42c5b11c6fd2_zps
and welded this.
And thats it ...
#311 rally515
rally515
  • 3,848 posts
Posted 10 August 2013 - 02:07 AM
Just looked through the whole thread alex and i'm feeling a little silly at the fact i,ve bought a load of panels :lol:  when i could have easyly wopped up a few £100 quids worth of pieces i,ve used >_<  live nd you learn i guess, although as for the mk2 i'm needing a few pe-made panels in certain areas haha
Great to see this is still very much moving forward and hope you can be up and running as soon as :proud:
Also: saw a comment of mine from back in 2012 that i dont even remember :lol: , how time fly's by aye :goaway:
Cliff
#312 alex-95
alex-95
  • 6,025 posts
Posted 10 August 2013 - 09:57 AM
Cheer's cliff,  Yep live and learn, Some panels are easy to make, Sometimes it's just as easy to buy the panels, I've certainly learnt alot from doing it.
It's not moving forward as much as I would like at the moment but other things crop up, but it will get done one day, I've thought when I'd like it done a few times, first being my 17th then that went to riv run 2013, now it's riv run 2014 I think But thats being optimistic i think :lol:
Haha, Some of the bits that I've done doesn't seem that long ago, but looking back some things were over a year O_O
ALex
#313 rally515
rally515
  • 3,848 posts
Posted 10 August 2013 - 03:32 PM
I know about that all to well :lol: , never set myself a goal to be honet, maybe i'l just set mine as to beat you possibly ? Ambitious maybe but a goal non the less ;D
Cliff
#314 alex-95
alex-95
  • 6,025 posts
Posted 13 August 2013 - 07:02 PM
Not really an update, just a couple of pictures, A while a go dad made a frame to bolt on to the toe board so that we could get the floor.
mk1 light conversion panel removed.
#315 alex-95
alex-95
  • 6,025 posts
Posted 03 September 2013 - 07:48 PM
Dad and I did some more work today, Dad ground down the welds on the floor and I Drilled out a couple of spot welds on the sill lip where they welded the oversill on the egde of the original sill and 1/4 panel bit. Then I plug welded it back on after removing it.
Thats about.
Any comments welcome.
Alex
