Alex's 1982 Hle Rebuild
785 replies to this topic
#286 grahama
grahama
  • 2,442 posts
Posted 27 January 2013 - 09:55 AM
Comming on Alex. What gauge metal did you make the seat brackets out of and how much further back will the seats sit??
Graham
#287 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 27 January 2013 - 10:08 AM
Impressive stuff! I'm liking how you are knocking up the repair panels where possible - that's a great way to learn!
Cheer's, It's alot more satisfying to make the panels rather than buying the whole section, and cheaper too :gimme:
Graham
Thanks Graham, I can't remember what gauge the metal is, but I'll post up how I made them tonight with a few measurement too. I think they move them quite far back, the second hole on mine is where the last hole on the originals would be.
Alex
#288 grahama
grahama
  • 2,442 posts
Posted 27 January 2013 - 04:05 PM
Nice one Alex, will be needing this mini guide as Matthew is 6' 3" tall lol.
#289 alex-95
alex-95
  • 6,078 posts
Posted 27 January 2013 - 07:22 PM
To make 4 Extended seat brackets we used, about 2 meters of*3mm x 25mm* and about 0.25 meters of *3mm x 80mm* steel. To make 4 brackets, 2 for each seat.
The original brackets are needed to get the holes in the right places, and the distance between the 2 uprights.
The 40mm peice is an 80mm peice cut in half.
This make's one bracket
Once these are cut out:
First off I welded 2 peices of metal to the angle of the cross member.
I welded the 2 25mm peices together using the angle gauge made.
grind down the welds and curve the tops.
Drill holes about 20mm from eachother by clamping the 2 together.
With the original bracket mark and drill holes for the bolts. Like above ^^
Then weld it together, again checking where the holes are and where the right angle peice goes.
Then weld in a small peice of metal between to strengthen it.
Drill 2 holes in the 40mm peice of metal to secure it to the cross member (we are going to use Rivnuts) then Bend it 90 degrees. and weld it on, so then when it's welded fits over the cross section.
This is all the peices.
All finished
How far it's moved back. It want move any further back else it'll foul the rear bin.
You may have to move the seat catch rails as it's to far back, I would drill one hole so that you can bolt it in two positions. where the last red dot is.
It's a lot more difficult to explain than i thought, If you need any help just ask.
Hope this helps
Alex
#290 grahama
grahama
  • 2,442 posts
Posted 28 January 2013 - 10:21 AM
Perfect Alex, might be a useful guide to many, maybe post it in the tech section and a moderator may pin it so it's not lost.
#291 alex-95
alex-95
  • 6,078 posts
Posted 28 January 2013 - 10:31 AM
Cheer's, I think I will tonight.
Also For the catch rail's put a bolt in the spare hole so if need be the bar can be moved forward and back easily.
#292 minimuk
minimuk
  • 1,947 posts
Posted 31 January 2013 - 09:17 PM
any special brackets for the steering wheel .... ;D might need to lower that one from standart
#293 Mini-Mad-Craig
Posted 31 January 2013 - 09:18 PM
They look brilliant mate... well done. Can't wait to see more progress on this
#294 alex-95
alex-95
  • 6,078 posts
Posted 31 January 2013 - 09:59 PM
Haven't thought about brackets for the steering wheel, Got plenty of time to do it though :lol:
Cheer's craig, I should be able to get on with it a bit more this weekend. :gimme:
#295 Driezzie
Driezzie
  • 662 posts
Posted 02 February 2013 - 02:47 PM
nice thread alex !
#296 alex-95
alex-95
  • 6,078 posts
Posted 02 February 2013 - 09:36 PM
nice thread alex !
Cheer's Driezzie.
#297 ToddM
ToddM
  • 55 posts
Posted 18 February 2013 - 10:35 AM
Looking good, Alex! I'd have given up on that front end a looooooooong time ago! Thanks for sharing the secret of the seat brackets, I might have to knock some off as my car came with none, I sat down in it to roll it down the driveway and fell backwards onto the back seat! D'oh!
#298 alex-95
alex-95
  • 6,078 posts
Posted 18 February 2013 - 09:59 PM
Cheer's Todd, The fronts not too bad, much more fun repairing it. They're pretty easy to make, and alot cheaper than buying them, Here's my "how to guide2 with a couple more pictures http://www.theminifo...-seat-brackets/, sounds fun :lol:.
I've owned it for 3 years today :ohno:, I have this week off for half term but like the past couple of weekends shouldn’t be doing that much as I've hurt my back :goaway:
#299 alex-95
alex-95
  • 6,078 posts
Posted 22 February 2013 - 07:28 PM
I did manage to get into the garage today, Helped dad do a bit of wireing on another project and did a bit of welding.
Welded the repair I made.
Then done a repair on the bulkhead.
Cut out.
Old and new.
Fully welded
inside
Thats about all I done today, other than wire brushing the number plate and front bumper mount things.
Any comments welcome.
Edited by alex-95, 22 February 2013 - 07:46 PM.
#300 alex-95
alex-95
  • 6,078 posts
Posted 02 March 2013 - 09:00 PM
We've done a bit more in the past week. There was a small hole in the top of the bulkhead. It's in a Tight space which we had to drill holes to cut the bit out.
And welded in a new peice in and ground down, which was also a pain.
While I was welding it in Dad took off the last peice of the wing.
So today made a new peice for it.
Dad took off the mounting bracket that fits between the inner wing and front panel.
Made a new peice and welded it in.
I cut out and welded in the inner wing repair.
I had to drill out the bottom to plugs and redo them as they didn't catch.
We did do a few other bits and fitted the seat brackets in the RITZ.
Any Comments welcome. :thumbsup:
Alex
    Bing (3)
