Alex's 1982 Hle Rebuild
780 replies to this topic
#271 Mini-Mad-Craig
Posted 02 December 2012 - 06:29 PM
Coming on well mate. You must be starting to see the light of fresh paint soon? :D Keep at it :-)
#272 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 02 December 2012 - 06:43 PM
Cheer's Craig. Yeah should be, Just have to finish the welding, grinding, other bit's on the body and paint prep. :D
I haven't done much this weekend, I got this wipac fog light off of ebay so gave that a quick polish.
Next weekend I'll try and get some more work done :gimme:
#273 minimuk
minimuk
  • 1,946 posts
Posted 03 December 2012 - 08:47 PM
you sure you put it on the Arch??
#274 alex-95
alex-95
  • 6,025 posts
Posted 03 December 2012 - 08:57 PM
of course :shifty: :whistling:
#275 alex-95
alex-95
  • 6,025 posts
Posted 11 December 2012 - 09:46 PM
An update from the weekend:
I started to wire brush the bulkhead so that I can give it a coat of paint to prevent the rust, I still need to do the boot and the passenger footwell.
Then I started on the front panel at there was a few holes where I didn't have a spot weld drill so took the bumper Lip off with a chisel. So I drilled the holes bigger and filed them sqaurer so that i could cut out repairs.
So then I set about welding them in, which I didn't get very far ... The gas run out >_<.
#276 alex-95
alex-95
  • 6,025 posts
Posted 15 December 2012 - 08:59 PM
Dad and I went and got some gas yesterday so i could crack on with a bit of welding.
Set the welder upand welded the front valance.
Then I set about replacing the patch on the passengers side subframe mount.
With that cut out I made two panels, one for the inside peice and one for the outside.
To get the bevelled shape I cut out a semi-circle in a peice of wood and clamped the metal to it.
it still needs to be adjusted and curved slightly so that it can be welded in.
Alex
#277 grahama
grahama
  • 2,442 posts
Posted 16 December 2012 - 09:25 AM
Nice work on the front panel Alex, Looks like the strengthening piece for the subframe mount needs your attention too. Coming along tho !
Graham
#278 alex-95
alex-95
  • 6,025 posts
Posted 16 December 2012 - 09:38 AM
Cheer's graham, it needs a bit of work there and small patch further up the inner wing.
Alex
#279 alex-95
alex-95
  • 6,025 posts
Posted 16 December 2012 - 08:04 PM
I had to make a new inner panel as the other didn't fit to the outer one. So with that made and the inside wirebrushed and kurusted, I welded them on.
With that welded in, I Started cutting out the rust in the inner wing.
There was loads of bloody spot welds
In the end I ground them off.
Any comments welcome.
Alex
#280 alex-95
alex-95
  • 6,025 posts
Posted 14 January 2013 - 07:04 PM
Not much of an update, I haven't really done much since the last update as I've got Exams this week And Dad and I have been doing work on the Ritz http://www.theminifo...ur-ritz-part-2/, So should be able to get going again this weekend.
I also got this today so should be able to take out the cones:
Alex
#281 Nossedout
Nossedout
  • 160 posts
Posted 14 January 2013 - 07:25 PM
keep up the good work!
#282 elpedro
elpedro
  • 93 posts
  • Local Club: north east mini club
Posted 15 January 2013 - 05:03 PM
wow grate thread such a joy reading keep up the good work have to remeber to keep an eye out for this one
#283 alex-95
alex-95
  • 6,025 posts
Posted 15 January 2013 - 10:38 PM
Cheer's, It's great getting comment's like that :D
#284 alex-95
alex-95
  • 6,025 posts
Posted 26 January 2013 - 08:51 PM
Not done much again, but other things have got in the way, We did try to remove the cones from the front subframe which didn't go to well as I stripped the threads, so we baught a m14 tap to tap the holes from unf to the metric size.
Anyway Today I carried on with the front panel. The drivers side subframe mount was rusty too, not as bad though.
Cut out the rust
Then I made a peice to fit, But didn't manage to weld it in.
We also made one extended seat bracket and Dad got the other parts ready to be made.
#285 PNL629G
PNL629G
  • 48 posts
Posted 26 January 2013 - 11:06 PM
Impressive stuff! I'm liking how you are knocking up the repair panels where possible - that's a great way to learn!
