Dash Pot Oil
Posted 02 October 2011 - 02:23 PM
Posted 02 October 2011 - 02:24 PM
Posted 02 October 2011 - 02:28 PM
Posted 02 October 2011 - 02:30 PM
whyI use 20w/50but i add some WD40 to thin it out a bit
Posted 02 October 2011 - 02:54 PM
why
thinner oil makes the piston rise quicker
Posted 02 October 2011 - 03:01 PM
Posted 02 October 2011 - 04:28 PM
Posted 02 October 2011 - 04:30 PM
Posted 02 October 2011 - 04:40 PM
stick to damper oil it is not going in the engine
Posted 02 October 2011 - 04:59 PM
Posted 02 October 2011 - 08:57 PM
Posted 02 October 2011 - 10:00 PM
Posted 03 October 2011 - 08:55 AM
Seriously, dashpot oil have to be choosen carefully because it dictates the mixture enrichment under acceleration.
It is part of tuning the SU carb. The needle profile, the spring weigth and the oil viscosity should all match together.
As above, studing how SU carbs work will really help you to understand how you can carefully select the correct dashpot oil for your carb.
Edited by jaydee, 03 October 2011 - 08:55 AM.
