Bump Steer
#16
Posted 14 October 2011 - 07:06 AM
#17
Posted 14 October 2011 - 07:17 AM
SHYFD - do you have a new steering rack or recon? I ask because once I swapped out my recon for new unit things got a whole lot better, admittedly at the same time I put the spacers in place also so there was lots of changes at one point in time.
The rack that came with my half built project is a NAM5058 from Mini Sport. I take it this was a new rack and I have the receipt for it. The bump steer almost vanished when I added the new ends and spacers.
#18
Posted 17 October 2011 - 08:14 PM
http://www.ozebiz.co...eory/align.html
#19
Posted 18 October 2011 - 07:11 AM
Just found a long but good description of Toe, caster and Camber if anyone needs more info.
What a good write up, proper english instead of techno jargon.
Edited by cptkirk, 18 October 2011 - 07:12 AM.
#20
Posted 18 October 2011 - 03:09 PM
I have been reading your posts, and your past post Andy. I too have the same high speed wiggle and it puts the living ****s up me so much so as i dont drive fast very often. I did some work on bump steer with a friend of mine and did exactly the thing you guys did. this didnt help me much so I put this down to play in the steering rack. I dont know how much help I can be but would love to bottom this issue so as to get more confidence in the car.
I was also doing some work on the front suspension as it seems that the front shocks are hitting the bump stop ( using cable ties as tell tales) and so am not getting full travel at the front. I also lengthend the rear shocks ( extended top mounts) as i wasnt getting much droop ( oo err missus) at the rear. I will sort out some pics at some point.
This was all done last year but as said not used car much this year and am hoping to get some work done on it later this year ready for next.
#21
Posted 18 October 2011 - 03:17 PM
This should help with the bump steer problem further more...without loosing too much turn in speed?
would you all be so kind to share your settings as a starting point for this discussion?
Mine are all ******* up and will need sorting soon.
Edited by andream88, 18 October 2011 - 03:18 PM.
#22
Posted 18 October 2011 - 03:36 PM
#23
Posted 20 October 2011 - 09:08 PM
Hi Guys
I think the lack of droop on my rear suspension is causing the knocking I hear. Would be intersted to see a pic of how you have sorted it.
I currently have all toe settings set to -3. Am going to get it set up again at -1.5 i think but after i sort the knocking on the rear.
#24
Posted 20 October 2011 - 09:28 PM
Mine currently is w/out arbs and it feels totally flat on the corners, i don't feel the need to get them...
what about you?
#25
Posted 21 October 2011 - 07:38 AM
#26
Posted 21 October 2011 - 03:00 PM
I imagine there wouldn't be as much roll from front to back caused by weight transfer... Just a thought...
#27
Posted 21 October 2011 - 05:57 PM
My rear springs are 8B 400 whatever that means..
#28
Posted 23 October 2011 - 01:57 PM
#29
Posted 24 October 2011 - 09:05 AM
@ shyfd - when you say you've slackend the springs what do you mean? As in they were done up too tight in the first place or that if you were to jack the car up the spring would not connect with the top plate of the suspension unit??
@ Blueminijohn - this is something I am toying with doing as I feel that the rear end is very soft when going over bumps in a straight line, I need to get a suspension uunit off the back to check the poundage, the front to me doesnt seem too soft, then I will give Protech a call about getting and uprated set of springs.
If i notice anything else whilst I am tinkering I will let you'all know.
Edited by cptkirk, 24 October 2011 - 09:07 AM.
#30
Posted 24 October 2011 - 06:32 PM
I had my springs done up so the bottom nut was almost to the top of its thread. Ive slackend it off so the spring is just held in place with a small amount of presure when the car is jacked up. This gives me a small amount of droop and no knocking but rides too low.
