Security Essentials And Recommendations
64 replies to this topic
#46 nafnaforiginal12
nafnaforiginal12
  • 282 posts
  • Local Club: Cumbria Mini Cruisers
Posted 02 October 2011 - 06:14 PM
Anyone know what's the easiest way to put a battery isolator switch in at the front?
#47 james962
james962
  • 2,677 posts
Posted 02 October 2011 - 06:19 PM
Removable steering wheel. Good deterrant.
#48 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 02 October 2011 - 07:34 PM
What's to know?
Run the main power feed up in to the car at the front, wire the isolated inline somewher 'under the dash, under the seat, rear bin etc' Continue power feed in to the boot to the battery. :)
Make sure to use rubber gromets everytime the cable goes through metal.
#49 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 05 October 2011 - 04:22 PM
So.. Alarms? Anyone recommend any?
#50 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 05 October 2011 - 08:39 PM
to be honnest I dont think a modern alarm system would be any use in a mini. The car has so many leaks and air gaps that any preasure sensitive sensors would be useless...The only thing that might work might be a door switches and bonnet and boot switches. you would need a remote arming device. If you could link it to some sort of dead bolt central locking that would be a real deterent. but the damage that the thieving toe rags would cause trying to open the door would be hellish...Solenoid deadbolts are very cheap and could easily be wired to a reciever. But it would mean cutting into the doors and B pillers...
#51 invisible_kid
invisible_kid
  • 516 posts
Posted 02 November 2011 - 09:21 AM
can get a wifi cctv camera for around 40 quid that even works at night, all u need is a hard drive and u can even watch it on ur smart phone at work. im thinking bout this cause i walk to work most of time and it means even if i just miss it i can make sure she is ok lol
#52 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 02 November 2011 - 09:29 AM
yeah i do like the sound of the cctv you can tap into anytime, its good piece of mind so you can see your cars still there but when if it does get stolen, the image quality didnt look good enough to ID the thief
#53 invisible_kid
invisible_kid
  • 516 posts
Posted 03 November 2011 - 12:02 PM
i would have to check bt cctv is getting better all time and more high deff so i would of thought u would be able to get a decent setup that could id someone without setting u bk a fortune. bt i have to hold my hands up i wouldnt kno
#54 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 03 November 2011 - 12:04 PM
Depends, the LED ones are awful. If you want a HD one then you prob cant stream it over the net or to your phone easily. Plus unless you count on them turning on the light which I doubt they will do, your stuck with the infrared type ones
#55 minimissionary
minimissionary
  • 999 posts
  • Local Club: Fylde Mini Club
Posted 09 August 2012 - 08:16 PM
#56 lorry
lorry
  • 249 posts
Posted 18 August 2012 - 07:45 PM
Does anyone have a security post infront of the mini?which this the best value for money?
#57 l_jonez
l_jonez
  • 1,453 posts
Posted 18 August 2012 - 08:44 PM
When mine was nicked it had no security (foolish I know) it now has a combined alarm&imobilizer aswell as a few features that I wont discuss on a open forum. Also now there's always another vehicle parked behind it on the drive now which means they would need to get that out of the way first.
Mine was nicked relatively early in the night 9am ish when I asked my neighbours if they saw/heard anything they just said they thought it was me going out as its not unusual for me to be out at night, so thought nothing of it.
#58 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 07 September 2012 - 07:00 AM
always leave with the steering on full lock befpre you put your steering security lock on so it cant be towed easy
#59 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 26 April 2013 - 06:09 PM
ive gotten a wheel clamp now.
Cant never have too much but it is a pain locking the thing up! sometimes i dont go out just because I cant be bothered to unlock it!
Wheel clamp, steering wheel lock, handbrake to gear lever lock, PLUS the usual.
Really thinking about a tracker....
short of chainging it to the ground (which I did think about lol.....)
#60 monkeypoker
monkeypoker
    Just On Tickover
  • 8 posts
Posted 28 April 2013 - 10:17 PM
Do it Mr Bean style and get a removable steering wheel!
