Posted 29 September 2011 - 12:16 AM
Firstly, before you strip the engine, you must check the oil pressure with a gauge and the oil pressure relief valve (if pressure is low) before going to the expense and time of fitting a new oil pump.
As regards the seal, it can be done both ways obviously depending on whether you are changing the pump. In either case, it is imperative that the sharp lip on the forward seal running surface is "hidden" from the seal as this can cause it to split - the problem you have now.
Essentially, you will need to cover the whole of the primary gear (splines) with a layer of insulation tape. Next, you need to gradually increase the diameter of the splines to match that of the seal running surface - you can do this with insulation tape, or find something which has the internal diameter of the splines and external diameter of the running surface (a modified spray can cap may help - cut off the top and split it down the side) then cover everything with insulation tape so that you end up with a nice smooth surface. Then cover the tape with a good smear of grease/oil. You should now be able to push the seal along the primary gear easily until it is next to its housing. Now the hard part. You need to push the seal "home" until its outer face is flush with the housing. By smearing a light coat of oil around the outside of the seal you should be able to start the insertion with finger pressure, but make sure the seal is square with the hole by applying pressure equally on opposite sides of the seal. This will take time and patience to get it right. Once started, either find a large metal tube and tap the seal home, or using a small block of wood (splinter free), tap the seal home lightly and on diametrically opposite sides.
If you find that you are replacing the oil pump, don't forget to check the idler gear endfloat. If you have not removed the engine and split the gearbox, the only way to do this is by removing the primary gear and oil seal and measure the endfloat through the oil seal hole. This is very tricky and should be done with the new gasket in place and torqued to the correct figure, Measure it several times to be sure. It can be done! Make sure that you grease the bottom (1st motion shaft) bearing before refitting the cover and pushing the roller bearings against their race. This should make fitting of the cover easier and eliminate potential damage to the roller bearing.
Finally, don't forget to measure the primary gear endfloat.
Keep us posted with your progress.
