Arch Rolling.
#16
Posted 28 September 2011 - 09:41 PM
#17
Posted 28 September 2011 - 09:44 PM
So basically the body work will flair out at the bottom so I wont need bolt on arches.
#18
Posted 28 September 2011 - 09:55 PM
#19
Posted 28 September 2011 - 09:59 PM
http://www.ebay.co.u...#ht_2335wt_1199
something abit like that ????
Yea that sort of thing. But balls am I paying that much lol.
#20
Posted 28 September 2011 - 10:00 PM
It's possible but not something you'd achieve without a serious amout of work. I've trying to figure something similar for my estate so I'll let you know how I get on.
Cheers. I'm sure it can be done its just finding a way of doing it. Theirs a company not far from me that do work on VWs and they do arch rolling so may go and speak to them and see if they have any ideas.
#21
Posted 10 October 2011 - 10:33 PM
Not really sure how well that will work but basically that is the look I'm trying to go for. I just hope I can get it too work.
#22
Posted 10 October 2011 - 11:09 PM
#23
Posted 12 October 2011 - 08:40 AM
#24
Posted 18 October 2011 - 06:50 AM
#25
Posted 19 October 2011 - 11:58 AM
but you'd get the same effect just blending in a set of grp2's with the lip taken off
What size tyres are you trying to hide?
#26
Posted 19 October 2011 - 01:41 PM
#27
Posted 19 October 2011 - 02:40 PM
Mind you, with all the skills required here, If you have access to an English wheel, just make them from flat steel to whatever shape/profile you want.
#28
Posted 19 October 2011 - 02:48 PM
This is not my work, i would have also blended the arches to the side skirts better if it was!
I do have possession of this shell and hope to make improvements to the mods before a repaint and rebuild.
Edited by Yoda, 19 October 2011 - 02:52 PM.
#29
Posted 19 October 2011 - 05:43 PM
1st off, couple of technicalities, rolling arches means taking the horizontal edge to a 'normal cars' wheel arch (pokes inside the wheel arch) and bending vertical. This leaves the exterior looking stock but allows you to run wider wheels without the arch cutting into the tyre. What you are referring to is flairing the arch. But the way that the arches are on a mini, you wouldn't be able to do it so you are going to need to create a more 'conventional' steel wheel arch.
I don't think you are going to be able to find a repair panel for another car that the 10's wont look lost in so this means you are going to need to make your own. The only way I can think of doing this is to use 2 lengths of thin steel rod, use 1 to form the upper curve of the arch (the top line of say a grp2 were it sits flush with the shell) and the 2nd to form the curve for the outer edge. By joining the 2 pairs of ends together (and prob a couple of rods to tie the 2 curves together so they don't spring apart) you can then make a card template of the sheet steel you will need to cut for the arch. you then tack weld the sheet steel onto the rods and there you have 1 flaired wheel arch ready to be welded onto your shell. If you can find the build thread of a clubby with a front engined RWD ZXR powered mini (was on ebay not that long ago), he made up his arches using this method
Thinking about it, you could use a set of mini arches as the basis of the formers for the steel arches, that way it'll make it easier to get them all the same and in proportion to the shell
#30
Posted 19 October 2011 - 06:18 PM
Click on the cover to view it
http://gb.zinio.com/...skuId=416130578
Edited by toaster93, 19 October 2011 - 06:19 PM.
