Arch Rolling.
Posted 24 September 2011 - 06:28 PM
Thanks.
Posted 24 September 2011 - 06:45 PM
Posted 24 September 2011 - 06:52 PM
in the euro scene, the only reason they roll the arches is to bend the seam on the arches upwards so that it removes the sharp edge, this stops the tyre being cut.
the other type of arch "rolling" is where the arch profile is actually extended so that you can "tuck" your wheel.
neither of which can actually be done o na mini because A) the seam is on the outside of the arch so cant touch the tyre anyway B) the seam prevents the 2nd type of rolling.
as tupers said, the only way to go REALLY low, is to cut the front arches (to stop the wheels from rubbing on lock) and to tub the rear arches.
Posted 25 September 2011 - 08:29 AM
This was the reason I wanted to do it. I just wanted to do something different as I'm a tad bored of all the arches you see at the moment. They all just seem the same. Would it work if I de seamed the seam between the wing and A panel just at the bottom bit making it basically one panel?
Posted 25 September 2011 - 09:07 AM
Cut the arch to the radius you want, bend a length of say 8mm diameter bar to a neat radius similar to the arch cut. Weld the bar to the inside/edge of the wing/a-panel and then blend it in.
You'll have a very strong arch and the edge will be nice and round.
Not seen it done on a mini before and not even sure it would work and not look gash, its an idea though???
Posted 25 September 2011 - 09:28 AM
Posted 25 September 2011 - 12:12 PM
Just wondering if anyone has done it to a mini before. I may see if I can find someone local who does it and get them to come out and have a look to see if they think they have a way of doing it.
Posted 25 September 2011 - 12:16 PM
Posted 25 September 2011 - 03:58 PM
Posted 28 September 2011 - 04:07 PM
Posted 28 September 2011 - 05:33 PM
jack
Posted 28 September 2011 - 06:15 PM
Posted 28 September 2011 - 09:20 PM
Posted 28 September 2011 - 09:25 PM
Posted 28 September 2011 - 09:26 PM
