As the title, I'm looking at possibly building a supercharged 998, it's going to be used everyday so I'm not looking for out and out power, just want something a little nippy
I've got a standard 998 engine (A-series) with 24,000 on the clock so I'll be using that. For the head and cam I was thinking about using MG Metro items(which I've got kicking about), would these be ok? if not what cam would be best suited? I also have an MPi cam if thats any good? will the standard pistons be ok for the output?
Also while I'm thinking about it, what exhaust manifold would be best a Cooper freeflow or LCB?
What I'm going to do is build the engine and use it without the supercharger and ignition setup to start with, so I need to do the cam before it is installed.
Any other advice would be helpful.
Thanks Richard
