Two Cylinder A-Series Engine
53 replies to this topic
#1 mab01uk
mab01uk
  • 12,413 posts
Posted 14 September 2011 - 10:50 PM
Very rare & interesting 2-cylinder Mini engine on ebay:
http://www.ebay.co.u...984.m1423.l2649
#2 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 14 September 2011 - 10:53 PM
Looks quite interesting, slightly pricey though ;D
#3 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 14 September 2011 - 11:05 PM
would be awesome to have but your sorta stuck without the gearbox at least, would have been cool to see what a mini would drive like with one in it though :lol:
Edited by Dan, 15 September 2011 - 05:25 PM.
Do that again and you'll get a warning. You know what I mean.
#4 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 15 September 2011 - 06:11 AM
Its just a paper weight with no crank/head/gearbox/pistons/rods but I'd like to know the story behind it
Edited by PIGEONTO, 15 September 2011 - 06:12 AM.
#5 TfcIan
TfcIan
  • 534 posts
Posted 15 September 2011 - 08:13 AM
Already been posted here http://www.theminifo...howtopic=202513
Admittedly not with the best title.
#6 mab01uk
mab01uk
  • 12,413 posts
Posted 15 September 2011 - 08:54 AM
There is an old photo of the full 2-cylinder prototype engine on its gearbox in this book:
http://www.haynes.co...47365&langId=-1
Mini: The Definitive History by Jon Pressnell, I would scan picture and post it but my copy is out on loan at present........
#7 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 15 September 2011 - 08:55 AM
its actually the third time, i await Bungle.
#8 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 15 September 2011 - 09:54 AM
I would hardly call it a paper weight. A standard gearbox with an adapter plate would solve the gearbox problem. Pistons and rods will be standard. Im sure kent would chop a camshaft in half for you (with the appropriate bits still attached) and I imagine a decent A-series specialist would be able to make something of a crank. Not a cheap project but by no means impossible.
#9 Dan6061
Dan6061
  • 761 posts
  • Local Club: -
Posted 15 September 2011 - 11:37 AM
What's the actual advantage of it then?
#10 mab01uk
mab01uk
  • 12,413 posts
Posted 15 September 2011 - 11:38 AM
If people don't follow basic forum guidelines by posting a sensible or descriptive title directly related to the content of their posts, then you must expect re-posts to happen................
#11 Wil_h
Wil_h
  • 3,244 posts
Posted 15 September 2011 - 11:42 AM
I guess, but for the engine to have value it must be historically correct. What you would end up with is something that never existed and was worse than a 4-cylinder engine.
It's a paperweight
#12 mab01uk
mab01uk
  • 12,413 posts
Posted 15 September 2011 - 11:48 AM
Compact and cheaper to build but I believe it was too unrefined and harsh/rough running in the end.
But there was a very quick 2-cylinder Special Saloon Mini Racer in the 1970's................... :thumbsup:
Designed and built by Gordon Allen from half a 1700cc BDA (so rated at 850cc). In the 1970's special saloons there was an 850cc class which was full of destroked/overbored 970 Cooper S engines, usually running exotic 8-port heads and the like. This 2 cylinder BDA was a real winner once a few niggles were overcome. It was used by Peter Day in a Mini and also a Fiat 500 (the "Mighty Mouse") Here it is at home in the Mini;
http://www.racing70s...ns/mini_065.htm
#13 dribble
dribble
  • 386 posts
Posted 15 September 2011 - 12:33 PM
" A two cylinder engine – made by literally cutting an A35 engine in half to create a 425cc twin – was rough and unrefined when used in an A35 test car.. So the now simple-sounding solution of placing the gearbox underneath the engine was born."
Taken from here http://www.1959minir...m/mini-history/
#14 Gulfclubby
Gulfclubby
    Gulf Boy
  • 751 posts
  • Name: Ben
  • Local Club: Berner Mini Club
Posted 15 September 2011 - 02:53 PM
I'd rather have a modern Fiat Twin Air engine:)
#15 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 September 2011 - 05:41 PM
Needs a bit more than that! The cam would have to be a custom billet, half a 4 cylinder wouldn't work. The timing would be terrible and look at where the dizzy drive has to be. Also this engine is the wrong way around, being a traditional A series layout from before the gearbox was stuck underneath and the engine turned around. The dizzy is on the wrong side, the manifold face is on the wrong side. You would have to make it run backwards, not a problem with a custom cam though. You'd have to use static ignition. And the crank would be billet too. The rods probably wouldn't be standard, no A series ever had the main bearings so close together so the big ends take up a fair bit of room. By the time there are crank webs in between those mains, even flat webs, there will be little space left for a standard A series big end. A more modern big end with thrust faces would be needed probably and with quite an offset too. So as said, possible but expensive.
Is this definitely the 2 cylinder do you think or is it half of the flat 4? It looks quite different from the other 2 cylinder block I've seen. I guess there were a few different development models though.
