Tim's Rev Counter... Original?
9 replies to this topic
#1 karl 93
karl 93
  • 86 posts
Posted 14 September 2011 - 08:22 PM
hi all,
just a quick question about the gauges in my mini..... basically all of them are smiths apart from the rev counter which says Tim on it.... are these the original gauges or do smiths do a rev counter also?
Karl
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 September 2011 - 08:29 PM
TIM gauges have never been standard, and if you have very many gauges the rest probably aren't either. Hard to know for sure though if you don't say what car it is and what gauges they are, or put up a picture.
#3 karl 93
karl 93
  • 86 posts
Posted 14 September 2011 - 08:34 PM
o sorry... its a 89 mayfair and i have a smiths speedo with a fuel gauge built in a smiths oil pressure and a smiths water temp gauge and then a Tim rev counter will get a picture up tommorow
karl
#4 jaydee
jaydee
  • 8,565 posts
Posted 14 September 2011 - 08:54 PM
Tim rev counter is aftermarket, smiths do a rev counter, never fitted as a standard, but did a 3 pod binnacle including a rev counter (ie clubman gt had them). There was another brand rev counter fitted as standard to authi and innocenti mini coopers (jeager?).
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 15 September 2011 - 12:28 PM
Jaeger is a bit misleading to throw into the mix. There is "British Jaeger" which is really just a re-badged Smiths. They were used on a lot of British cars up until the mid-1960s. Then there is a continental Jaeger used on many French cars (in particular). The French Jaeger gauges have nothing at all in common with British Jaeger. I have not seen Inno gauges up close but I would have expected them to Veglia-Borletti. While I have a friend in Chicago who has an Authi, I've never seen his car to know what gauges the Spaniards used.
#6 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 15 September 2011 - 12:35 PM
Sounds to me like a central speedo setup if its the big speedo with a fuel gauge built in. In which case the entire thing isnt original let alone the rev counter.
#7 jaydee
jaydee
  • 8,565 posts
Posted 15 September 2011 - 01:12 PM
Yes Doug you're right about the veglias, but there were either veglia and jeager instuments:
http://www.inno-mini...00/Interior.htm
This from a 998cc
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 15 September 2011 - 04:18 PM
Cool Jaydee. Thanks for the link.
The Inno sure had a nice looking interior.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 September 2011 - 05:57 PM
As above, none of your gauges are original. An '89 Mayfair should have the offset 3 clock pod, one speedo, one fuel/water/warning lamps and one tacho. All about 110mm, in a binnacle and not badged Smiths. It should have Nippon Seiki instruments.
#10 karl 93
karl 93
  • 86 posts
Posted 15 September 2011 - 06:17 PM
o right okay... thanks guys,... if I was to sell the smiths gauges do you know if they are worth anything?? and is it easy to pick up the original 3 clock set up as I am looking to get some custom clocks from gallileo gauges to fit them,
Karl
