Carbon Fibre Body Shell
Posted 13 September 2011 - 07:28 AM
My other question is that because there is a lack of them or i just cant find them, is there a reason why people dont have a carbon shell, i looked at a new steel shell but i dont want it to rust out in a 10 years time again
Im new to the car world and looking for advice, what are the experienced peoples views on steel v carbon
Darren
Posted 13 September 2011 - 08:51 AM
Pretty sure you can only get a fibreglass shell, and then carbon firbre bonnet, doors front etc
Out of interest what did Arc angles quote?
Posted 13 September 2011 - 09:03 AM
Do you want pure carbon or composite mix?
absmotorsport.net but it is possible for variations that are not on the site...
Posted 13 September 2011 - 12:24 PM
I was thinking of going for the carbon because i do think it looks good, but mainly i want to turn the mini into a little track car with plans for a AWD kit and a large honda lump so i want max strenght combined with the lightest weigth. Option 3 looks like idea to go with.
The car has a fair bit of rust so was thinking bout putting a new steel shell with lots of carbon bits like front fip doors ect but would like the hole thing to be once piece carbon shell for lightness.
Does anyone know any reason why there might not be a carbon shell for sale apart from the price, ive seen some "home made" ones on post here before that got snapped up really quickly for less then a grand.
I wasnt aware of the abs site and had a look, there is a carbon composite shell for £4,500. Im guess this is the same quilaty and makeup as the option 1? Would it be possible to make that shell with the weave showing?
Edited by scubalegg, 13 September 2011 - 12:31 PM.
Posted 13 September 2011 - 09:47 PM
Also I can be fairly sure you haven't seen a genuine carbon fibre shell for sale at less than a grand, more likely fibre glass.
Edited by Tupers, 13 September 2011 - 09:49 PM.
Posted 14 September 2011 - 02:10 AM
Posted 14 September 2011 - 09:32 AM
The 2 carbon shells ive seen are
http://www.16vminicl...ead.php?t=19084
http://www.theminifo...howtopic=133680
Both a few years ago now tho.
Ill have to do some more digging into this IVA testing. Surely it cant be that hard to pass with all the kit cars you can buy and build yourself?
Posted 14 September 2011 - 12:14 PM
Posted 14 September 2011 - 05:54 PM
Never thought of using a spaceframe with a carbon skin. What is the advantage of doing this, surely this is alot harder to build and takes alot more customiation? Would it be stronger and lighter?
The difficulty of manufacturing it really depends on who's doing the work. It wouldn't really need any customisation as it would be designed from the ground up to suit the component you've chosen. That said the design stage would take a fair amount of time. Check out SukiDawg's thread in the projects section and you'll get what I mean. A spaceframe would also allow for greater modification in the future as it's easier to remove and change things like shock mounts on a steel frame than it would be on a carbon monocoque.
It's likely that full spaceframe car would be heavier than a monocoque but considering you should really fit a decent cage in a composite shell I can't imagine there would be a huge difference.
Edited by Tupers, 14 September 2011 - 05:55 PM.
Posted 14 September 2011 - 06:10 PM
does carbon sag over time like fibreglass can? would consider a carbon bonnet and arches to be fair
if i was you why not just start with a good steel shell and stick as much carbon on it, floor, bootlid, front end, roof, i think iva would still be a pain in the arse but not as bad as a complete carbon body, would probably be registered as a kit car that way
Posted 14 September 2011 - 08:55 PM
Would this still need an IVA test if the roof, doors, boot, front flip was replaced with carbon parts?
Posted 18 September 2011 - 08:38 PM
Posted 19 September 2011 - 01:51 PM
Thanks for the advice
Posted 19 September 2011 - 05:37 PM
