- HIF44 carb. Has had a full strip and rebuild using genuine SU gaskets, dashpot plunger and seals etc. The butterfly has been thinned according to D.Vizard and smoothed out the internals. I spent ages polishing the dashpot which now looks nice and shiny. I also degreased the main body and sprayed it silver. Jetted to suit a 1380 but can easily be changed. Also includes heatshield and screws for air filter. £65 posted
- Minisport alloy water heated inlet manifold. Smoothed out internally and polished for improved air flow. Every HP counts! £30 posted
- K&N 1 3/4" cone filter to suit a HIF44 carb. Good condition. £20 posted
- Standard alternator. Bought this second hand and was going to use it in my project but have recently purchased a new 70 amp one instead so no need for it. Don't know if it works though as i have no way of testing. Sold as seen. £20 posted
- Stainless steel 2" backbox. few scratches but will clean up. £10 COLLECTED too heavy to post unless a courier is arranged.
- AF460 copper head gasket for 1275 engine BRAND NEW. £6 posted
- Verto clutch slave cylinder mount. £6 posted
- Verto clutch plunger and short arm. £6 posted
- A+ 1275 conrod bolts with nuts. £5 posted
- Bottom engine steady mount plate. £3 posted
