Rocker Cover Breather
41 replies to this topic
#31 Jack BRCG
Jack BRCG
  • 66 posts
  • Local Club: Torbay Mini Club
Posted 12 September 2011 - 08:12 PM
i have 1 of the breathers connected to the carb the other has a filter on it. but iv run all 3 of my engines like this without any problems. i used to have both connected to the carb but it was a bit of a homemade system that wasnt great, i was advised by my local mini specific garage that 1 breather to the carb is enough. i think im just gona leave it all for now and ask when its roaded. thanks tho
#32 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 12 September 2011 - 08:22 PM
Ah, OK. Your system is not working, did the garage tell you it was OK to have one breather open and one to the carb? It's not.
Your engine is ingetsing too much air through the system, the carb must have been tuned to compensate but it won't be working properly. With one side connected to the carb and the other open, the carb is drawing in loads of extra air. The two breathers should be connected together and then the pair connected to the carb. Or the whole system open vented and the carb connection sealed. Doing it half and half is not a good idea. Connecting it up properly is almost certain to reduce some of your oil leaks, unless they are down to damaged gaskets or loose joints or something.
#33 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 12 September 2011 - 08:25 PM
Be quiet you're not helping the initial question if you wish to argue further PM me, if you must.
or you could just admit you were wrong, you told roy he was wrong and now you dont want to admit it on the forum.
May I suggest that if you have nothing useful to say you don't say anything at all.
Like I said to the other member, if you must continue this PM me, it doesn't help the OP at all! - in fact you haven't actually contributed to this thread in a positive way at all, just tried to snipe at people.
Anyway, as Dan, who has beaten me to it, suggests either have the whole system open to the atmosphere, or have a closed loop system, the half system I've seen people employ including your setup is not the most efficient system and will cause the carb to run out of tune as the conditions of the crankcase changes due to the large amount of air being sucked through.
#34 liirge
liirge
  • 4,097 posts
Posted 12 September 2011 - 08:26 PM
just go on ebay and buy a very cheap early engine rocker top with the breather pipe in.
Sorry I was wrong there was the above insightful comment.
#35 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 13 September 2011 - 07:09 AM
eayest way is .. just have a small pod filter on the timing chain brether ( if its there . wilth a pipe bringing it up to the radiator support ... same on the breather on the drop gear case ( if its there ) rocker cover with vent just there .. or if you have hs4 to the airbox out put . and any cap . and the vent on the carb just piped away from the manifold
Edited by new_zealand _minis, 13 September 2011 - 07:10 AM.
#36 Jack BRCG
Jack BRCG
  • 66 posts
Posted 13 September 2011 - 10:06 AM
right so on your advice iv gone and got some breather pipe and a y peice to connect the two up.
#37 liirge
liirge
  • 4,097 posts
Posted 13 September 2011 - 10:16 AM
So they connected together and then T'd into the carb? as just connecting them together is the worst thing you can do!
They should be T'd up with one part going to the carb.
#38 Jack BRCG
Jack BRCG
  • 66 posts
Posted 13 September 2011 - 10:18 AM
yeah thats what i meant, connected into the t then the 1 pipe from the t to the carb.
#39 liirge
liirge
  • 4,097 posts
Posted 13 September 2011 - 10:22 AM
Here is the world crudest diagrams - those rectangles are hoses
#40 liirge
liirge
  • 4,097 posts
Posted 13 September 2011 - 10:23 AM
Excellent decision old boy!
#41 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 13 September 2011 - 06:12 PM
You will probably now find your car is running rich, but more predictably. It will just need an adjustment to compensate for the reduced airflow.
#42 Jack BRCG
Jack BRCG
  • 66 posts
Posted 14 September 2011 - 12:41 PM
haha, thanks for the diagram, but i did know how to do it already as i did have 1 in before.
yeah il just conveniently fit it a few days before the rolling road session
