Rocker Cover Breather
Posted 11 September 2011 - 01:03 PM
Posted 11 September 2011 - 02:21 PM
Posted 11 September 2011 - 04:05 PM
Posted 11 September 2011 - 05:12 PM
Posted 11 September 2011 - 05:18 PM
Can I ask why you are doing this?thanks il have a think. i thought i could just add one and keep the crankcase breathers on. hmmmm
Posted 11 September 2011 - 05:21 PM
Edited by bmcecosse, 11 September 2011 - 05:21 PM.
Posted 11 September 2011 - 05:32 PM
Yes but it completely changes how the breathing system works, it was set up very differently when they had the standard breathing rocker cover, if i remember rightly, what do you think the point of the oil filler cap that has a hole in for?Yes - buy a rocker cover that already has the breather - I don't know WHY they evr deleted this breather. Your engine needs all the breathers it can get - and connect them all to the carb inlet pipe to remove the carcinogenic fumes which you definitely don't want to be breathing.......
Posted 11 September 2011 - 05:33 PM
Because for the ventilation system to work there has to be somewhere for a controlled amount of fresh air to come into the crankcase and in order to blow out all the crud from everywhere the air has to flow through in a controlled route. The air flows in through the breather that already exists in the rocker, the one inside the filler cap where a small hole allows a metered amount of air in. The early breather systems were updated because they didn't work very well. The positive ventilation system is better by far than a basic open to atmosphere system where each part of the engine is directly vented through a filter. And if you just connect each part up to the carb without letting fresh air in somewhere, the engine will be pumping against a partial vacuum it is creating itself which won't be good at all.
Posted 11 September 2011 - 05:38 PM
Posted 11 September 2011 - 05:46 PM
Posted 11 September 2011 - 05:54 PM
Posted 11 September 2011 - 06:37 PM
Really no oil cap you've ever owned is vented? that's odd....pretty sure Dan has already mentioned above that you cant get caps with out a vent in them.,,It's important or remove all the fumes - and yes - if the engine is in good condition, leave one breather open to pull air through - but if it's a bit 'secondhand' and is blowing fumes out - it's best to connect all the breathers together and in to the carb. I have done it directly into the inlet manifold (with a 3mm restrictor) on a high power engine that was prone to fumes and oil leaks when run hard..... The breathers connected to the manifold made a huge difference. The caps I have don't have holes
Posted 11 September 2011 - 06:39 PM
http://minispares.co...id=35569&title=
http://minispares.co...id=42603&title=
Posted 12 September 2011 - 09:33 AM
i wanted to do it as i get oil leaks at high pressure. all gaskets have been checked and the crank case breathers have been cleaned out.Can I ask why you are doing this?
Posted 12 September 2011 - 10:30 AM
