Rover Metro Gti 16V Engine ?
4 replies to this topic
#1 Collins
Collins
  • 22 posts
Posted 03 September 2011 - 10:38 AM
can you put this engine in a mini like you can the other metro engines ?? like the metro 1275 engine ??? HELP
#2 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 03 September 2011 - 10:55 AM
Yes but not in the same way. You need to custom build a subframe to house the K-series as it shares no likeness with the A-series. The wiring will also either need to be spliced or the Metro loom will have to completely replace the Mini loom.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 September 2011 - 11:38 AM
The Metro 998 and 1275 engines are the same A+ units as fitted to the Mini, so installing them is straightforward but also doesn't really offer any difference from standard. The later Metro engines of different sizes are K series units and completely different engines. Fitting them is by no means easy without a reasonable amount of mechanical knowledge and experience, but not impossible.
#4 R1minimagic
R1minimagic
  • 4,660 posts
Posted 03 September 2011 - 11:43 AM
Have a look on 16vMiniClub website, there will be a K series section on there with loads of people that have done it
#5 Collins
Collins
  • 22 posts
Posted 03 September 2011 - 12:40 PM
ok thanks for all the help really appreciated
