Broken Indicator Stalk Clamp? Heres A Solution!
6 replies to this topic
#1 jackmason
jackmason
  • 522 posts
Posted 02 September 2011 - 03:57 PM
Theres alot of mini owners out there who have had this very problem.
It's happened to me twice!
Below is a rough guide to what i did, sorry for the lack of detail and photos. (Done this a month ago and only just got around to posting)
Broken Clamp
Attached File  Stalkrepair1.jpg   60.46K   31 downloads
-I removed the small broken part which the clamp bolt goes through
-I found a Jubilee clip and cut a section out of it
-Size it up and bend it so that it fits the contour of the clamp
-Angle the end up
Attached File  Stalkrepair2.jpg   57.76K   21 downloads
-Then drill the hole in the angled up end
-Find a course threaded short self tapping screw
-Drill a hole near the other end of the bent jubilee clamp for the screw to go through
-Place the new clamp in position and make sure its level with the edge (See picture below)
-Mark the plastic in the newly drilled hole
-Make a small pilot hole in the plastic slightly smaller than the screw being used to attach the clamp
-Fix the clamp in place with the screw and voila!
Attached File  Stalkrepair3.jpg   58.46K   28 downloads
Hope this helpful to some of you, if there are errors or steps which you think should be added then let me know and i can update.
Im also aware from seeing one of the most recent mini magazines that you can now buy the new stalks from minispares i believe? There around £40 for the side with the clamp.
#2 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 02 September 2011 - 06:25 PM
this is actually brilliant cus i was about to go and get some other ones so thanks :D
Adam
#3 jackmason
jackmason
  • 522 posts
Posted 19 January 2012 - 12:35 PM
Adam
No Problem, glad i could help. (sorry for the delayed reply) Hope it worked out fine for you.
#4 Bishop IRL
Bishop IRL
  • 109 posts
Posted 20 January 2012 - 01:56 AM
Fantastic and thanks for sharing
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 20 January 2012 - 04:41 AM
I wish I had seen this thread back in September. There was another recent thread on this topic and your fix certainly sounds like the best repair method.
#6 andyapanel
andyapanel
  • 623 posts
Posted 22 January 2012 - 06:59 PM
You're The Man!!! Brilliant idea.
#7 jiminwatford
jiminwatford
  • 310 posts
Posted 20 February 2024 - 11:19 PM
Brilliant. I used this today  :thumbsup:
