Bumper Less Mini
24 replies to this topic
#1 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 30 August 2011 - 08:57 PM
Could someone please post some pics of there mini without bumpers on this post. I am considering doing it to my mini but I want to see what it looks like first. Also how hard is it to do the required work ? Thanks
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 August 2011 - 09:07 PM
can you weld ?
#3 Andrew O
Andrew O
  • 1,425 posts
Posted 30 August 2011 - 09:09 PM
Yeah I can weld and my dad has a close friend who does it for a living, Why ?
#4 Tupers
Tupers
  • 4,138 posts
Posted 30 August 2011 - 09:26 PM
He asks because you will need to weld the rear panel, boot floor and valance together if if want to debumper the rear as well as the front.
The front is just a case of removing the number plate and bumper and then locating the spot welds on the bumper lip drilling them out. You'll also need to primer and paint on the area where the spot welds where or you'll end up with rusty spots on your valance.
On the rear ideally you need to remove the boot, bumper, lights and fuel tank. With this done you weld the rear panel to the boot floor from the inside and the rear valance to the boot floor from the underside (a good time to replace your valance and closing panels if they're looking crusty). Once you get this far you can grind/cut off the bumper lip off, fill, sand and paint the area done you're pretty much done. I'd recommend welding 100MM at a time and then letting it cool to save you warping the boot floor and/or valance.
#5 Andrew O
Andrew O
  • 1,425 posts
Posted 30 August 2011 - 09:28 PM
Thanks for that, What I really need is pictures...... Anyone ??
#6 mini77
mini77
  • 581 posts
Posted 30 August 2011 - 09:39 PM
#7 Tupers
Tupers
  • 4,138 posts
I know some people have got blow by blow pictures of how it's done on their build threads and in the bodywork section, it shouldn't be to hard to find them with the search function.
On a side note it's worth measuring to make the the rear panel and valance are level at the base of the bumper lip to save finding a step there when you grind the lip off.
#8 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 30 August 2011 - 09:42 PM
h4wx1e on here has a deseamed and debumpered mini.
heres a few pics from the sutton club site.
http://suttoncoldfie...albumid=8944679
#9 Andrew O
Andrew O
  • 1,425 posts
Posted 30 August 2011 - 09:47 PM
I really like the look of that
#10 Mini-Mad-Craig
Posted 30 August 2011 - 09:58 PM
Just go through some galleries. Plenty of people have de-bumpered Minis!... It doesnt take long to find them
#11 Mini-Mad-Craig
Posted 30 August 2011 - 10:00 PM
Uploaded with ImageShack.us
#12 Andrew O
Andrew O
  • 1,425 posts
Posted 30 August 2011 - 10:03 PM
They all look really nice
#13 asahartz
asahartz
  • 227 posts
Posted 31 August 2011 - 11:33 AM
Here's Nemo:
As others have said, the front is easy, just grind the lip off; the back needs reinforcing welding in. As the rear panel, by design, is turned out to spot-weld to the boot floor & valance, it really needs a thin L-section welding inside the boot as well as under the car for the valance - just fit a new valance as they're cheap.
#14 Andrew O
Andrew O
  • 1,425 posts
Posted 31 August 2011 - 12:40 PM
That's the look I want
#15 Jeano
Jeano
  • 72 posts
  • Local Club: On the Hunt for one:)
Posted 31 August 2011 - 01:37 PM
i got told mine was debumpered?
