My 75 Mini Pickup Project In Bolivia
68 replies to this topic
#61 cooperS
cooperS
  • 116 posts
  • Local Club: MOC Santiago, Chile
Posted 05 December 2015 - 06:59 PM
excelent Job! I read your post on a Chilean forum and all your problems with a chap right there....at the end of the day the work on your pick up is awesome!
#62 fwdracer
fwdracer
  • 269 posts
  • Local Club: Mini7 Racing Club
Posted 06 December 2015 - 06:55 PM
Brilliant
#63 David128
David128
  • 644 posts
Posted 06 December 2015 - 07:00 PM
So much skill shown and no new panels it is a credit to all involved. Just goes to show what can be done with imagination and talent. So impressed
Edited by David128, 06 December 2015 - 07:00 PM.
#64 minipete
minipete
  • 458 posts
  • Local Club: East Yorkshire MOC.
Posted 06 December 2015 - 08:21 PM
Thats brilliant.
#65 slidehammer
slidehammer
  • 1,152 posts
  • Local Club: LSMOC
Posted 30 December 2015 - 07:26 PM
Very nice looking project indeed
#66 Richard1
Richard1
  • 54 posts
Posted 04 July 2017 - 11:59 PM
Did a few small things to it:
Made a vinyl cover for the bed
Put an oil temperature gauge in the transmission
Lined the hood/bonnet with Dynamat hoodliner to cut the engine noises
And a skid plate, after replacing the flexible coupling on the exhaust and cutting the exhaust shorter to raise it.
adding a fuel pressure regulator
#67 pete l
pete l
  • 1,366 posts
Posted 05 July 2017 - 12:50 PM
You really need to get more overlap in any joins than that, weld is weaker than pressed and rolled steel sheet.
Is this true ? I'm starting to worry about my car now !
#68 MacGyver
MacGyver
  • 1,027 posts
Posted 06 July 2017 - 07:22 AM
Depends where... But Not necessarily.
#69 Ethel
  • 25,741 posts
Posted 06 July 2017 - 12:58 PM
Weld thins, by the surface tension pulling the melted material in to the bead, and anneals the metal it's joining. A thicker, more rigid, bead is also a stress riser. Welding is still going to be stronger than many other ways of sticking components together, but joints should be designed accordingly - look at any production car and you'll see the joins are dispersed with maximum overlap.
