Leyland Mini 1000 1980 Restoration Project
#16
Posted 19 October 2011 - 07:54 PM
Hi Graham, yes don't worry, any rot if anything worse than just surface rust has been cut out and replaced with new panels or a repair. The inner sills will be, or should I say, have been replaced as these posts are currently a year behind. I should have started this topic earlier but just never got around to it.
Thanks hugh, that panel was made simply by laying the metal on the stepped edge of a vice, and knocking the edge down into the step. I didn't have a joggler at the time but the vice did the job a treat!
Here are the pictures of the completed door step.
I spot welded the seams of the A post. Much quicker and neater than MIG welding and looks more original. Not that you'll see them when the seals are on!
Thats the drivers door step done. Thanks for looking.
#17
Posted 19 October 2011 - 09:00 PM
Graham
#18
Posted 21 October 2011 - 08:13 AM
All the best
Hugh
#19
Posted 21 October 2011 - 10:00 PM
Another repair piece was made for the passengers side and welded in at the bottom of the inner A post.
New door step welded in at either end and spot welded down the A post seam.
#20
Posted 22 October 2011 - 09:48 AM
Graham
#21
Posted 22 October 2011 - 08:30 PM
Anyway with the shell on its side, I could see exactly what horrors had gone on through the years. Patches had been welded over all of the slinging brakets and it had also been treated to a pair of over sills! After removing the drivers side over sill, the damage to the inner sills could be seen - lots of rust!
#22
Posted 26 October 2011 - 09:51 PM
I will add the pictures of the replacement floor section in the next few days. Having a few issues with uploading them at the moment since the last Adobe Flash update.
Thanks.
#23
Posted 27 October 2011 - 06:57 PM
Hugh
#24
Posted 27 October 2011 - 07:49 PM
#25
Posted 28 October 2011 - 07:42 PM
#26
Posted 28 October 2011 - 09:06 PM
#27
Posted 29 October 2011 - 07:27 PM
Thanks 123grosso, I appreciate the comments.
More to come soon.
#28
Posted 30 October 2011 - 12:52 PM
keep up the good work! some great welding going on here!
Ed
#29
Posted 31 October 2011 - 09:03 PM
Trial fitting the panel.
The companion box closing panel was removed from the original sill and cleaned back to bare metal. Only rusted at the rear end so trimed this shorter as not all needed and primed. With the floor panel clamped in place, the closing panel was lined up and clamped. The floor was then removed to spot weld together.
With the floor refitted welding began.
The rear subframe was temporarily refitted to locate and weld the heal board. This was a complete Heritage heal board HMP441008, which I cut in half to help keep floor square, by only doing half at a time and to aid correct location of the subframe mounting points.
Finally spot welded the inner sill/floor to the door step.
Thanks for looking.
#30
Posted 31 October 2011 - 09:53 PM
Hugh
