Leyland Mini 1000 1980 Restoration Project
#181
Posted 18 March 2012 - 09:02 AM
#182
Posted 19 March 2012 - 01:05 PM
#183
Posted 19 March 2012 - 10:15 PM
#184
Posted 20 March 2012 - 10:30 AM
http://www.weldequip...leece-115mm.htm
might save you a few pennies.. very good service i've had in past from tis company.
#185
Posted 20 March 2012 - 10:58 AM
Hugh
#186
Posted 20 March 2012 - 01:02 PM
Just order a couple
Chris
#187
Posted 20 March 2012 - 07:23 PM
Edited by minifcd, 20 March 2012 - 07:23 PM.
#188
Posted 20 March 2012 - 10:47 PM
Thanks for that link danny. I've saved it to my favourites list incase I need to order any more at some point.
ordered some to from them, to be honest most welding shops sell them, but not at that price. Thanks Danny, should have know weldequip, I bought stuff from them before
#189
Posted 21 March 2012 - 12:08 AM
#190
Posted 26 March 2012 - 06:12 PM
#191
Posted 26 March 2012 - 09:49 PM
Copper used to help when welding the joins in the gutter.
Pieces tacked in all the way to the rear.
And then welded from above. This shows the penetration on the under side.
Top side.
Then the time consuming bit, grinding and blending the welds, on the underside first. Not good for the neck working upside down with a grinder! Had to keep building up weld on the joins and grind and file back, as I really don't want to use any filler on the gutter.
Still got the underside of the gutter to do above the drivers door.
But the edge of the gutter doesn't look too bad at all. I'm quite pleased with how its turned out.
Still got the inside of the gutter to grind down to, but ran out of time and thought i'd better give the neighbours a break from the noise!
Thanks.
#192
Posted 26 March 2012 - 09:53 PM
#193
Posted 27 March 2012 - 01:27 PM
#194
Posted 27 March 2012 - 01:44 PM
#195
Posted 28 March 2012 - 11:34 AM
Great work as usual! I just wanted to ask a quick questions. I noticed you've been stripping all the panels back to bare metal when you are working on them. Are you then using an etch primmer to seal these prior to painting?
If so I just wondered what type? rattle can etc.? I've heard lots of people say various things so I'm not sure what to treat the panels with the stave off rust before the restoration is complete. I've also heard people saying that their etch primer sometimes reacts badly with the final top coat - have you any experience of this?
