Minispares Water Pump Engine Stabiliser
28 replies to this topic
#1 benb12
benb12
  • 1,483 posts
Posted 25 August 2011 - 12:15 PM
Has anyone had any experiences with the engine steady that Minispares sell which bolts to the waterpump? It says on their website that it "fits all minis including MPi" yet me and a friend tried fitting one last night and couldn't because of the bypass hose. Has anyone come up with a solution to this? All I could think of would be to weld an extension onto the bracket so that it clears but I don't know if the stabiliser bar would adjust that far. Conventional ultimate engine steady is not really an option due to the 'stat housing having a sandwich plate.
Cheers,
Ben
http://www.minispare...id=40991&title=
#2 benb12
benb12
  • 1,483 posts
Posted 26 August 2011 - 03:28 PM
Bump! :)
#3 liam1288
liam1288
  • 602 posts
Posted 26 August 2011 - 04:12 PM
minispares do do an ultimate engine steady for spi and mpi for use with the sandwich plate... looks kind of similar to the standard ones but a little bigger and longer pole in the middle. its about 28 excluding vat. was going to buy it yesterday but you need to drill another hole in the bulckhead i think...i dont know why its not on their site but moss europe do one to the rad too, apparently that fits all minis (dont know though) but thats a bit more money...
#4 benb12
benb12
  • 1,483 posts
Posted 26 August 2011 - 05:57 PM
Sounds like a possibility - why do you need to drill another hole in the bulkhead though? The other one wouldn't work because the mini has been converted to use the metro rad so is therefore front mounted.
Cheers,
Ben
#5 Duncy H
Duncy H
  • 388 posts
Posted 27 August 2011 - 05:15 PM
I too have had a problem fitting one of these, here is a pic to explain the problem...
Sorry to hi jack a bit :P
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 27 August 2011 - 06:05 PM
Why do you need this extra bit of hardware - the standard arm is perfectly adequate if fitted with poly bushes at ONE end..........
#7 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 27 August 2011 - 06:06 PM
which end??
#8 Duncy H
Duncy H
  • 388 posts
Posted 27 August 2011 - 06:21 PM
My engine still rocks with good poly bushes in slightly, with a poor quality manifild/y-piece the seal is hard to maintain. So with the extra stabiliser I hoped it would cut down on it and get rid of the problem.
#9 Gillybobs
Gillybobs
  • 243 posts
Posted 22 July 2018 - 08:02 PM
Cheers,
Ben
Just done a search and found this as I'm thinking of this type of water pump engine steady . What's the issue with the bypass hose ? Wondering if I'm better getting this sort of engine steady for my car
http://www.minispare...c/MSSK1301.aspx
#10 nicklouse
  • 18,577 posts
Posted 22 July 2018 - 08:09 PM
Cheers,
Ben
look at the DSN retrosport stabilisers. so much better than any of these bolt on things.
#11 Gillybobs
Gillybobs
  • 243 posts
Posted 22 July 2018 - 08:26 PM
Cheers,
Ben
Well above my budget . I don't understand your comment about bolt on things surley the DSN one bolts on ?
#12 racingbob
racingbob
  • 3,061 posts
Posted 22 July 2018 - 08:58 PM
just buy the 2 stabilzors that fit to the gearbox on to the subframe left and right
#13 nicklouse
  • 18,577 posts
the DSN one is part of the thermostat. so the loading goes into the bottom of the mountings. all the others go in at the top of the mountings. and can cause leaks. and they are a pain in the to work around. but they were the best we could get 30 years ago and they were crap then and still are.they always make more work than needed.
#14 Gillybobs
Gillybobs
  • 243 posts
Posted 22 July 2018 - 09:36 PM
So I take it they work! Do you still retain the engine stabilizer that goes to the front of the subframe from the clutch side ?
#15 Spider
  • 14,840 posts
Posted 23 July 2018 - 05:41 AM
An MPI with a water pump by-pass hose?   Errrr,,,,,,ummmm,,,   I don't think so.
The Aussie Minis and Mokes had a factory one that fitted under the thermostat housing. The engine side of these is brill, but the way the executed the body side made them almost useless but easily improved upon.
