Blue Smoke On Gear Change And Startup
8 replies to this topic
#1 Cerberus
Cerberus
  • 989 posts
Posted 24 August 2011 - 04:56 PM
Right, just started getting puffs of blue smoke on startup and when I change gear.
Am I right in thinking that it should just be the valve seals?
We did a compression test a few months ago and was getting around 180 psi on all cylinders IIRC.
Didn't really notice any smoke then, but you can see it pretty clearly now.
Still pulls fine, and its not there under full throttle, only when changing gear and startup.
#2 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 24 August 2011 - 06:13 PM
im sure blue smoke is burning oil, cant be much more help than that unfortunately.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 24 August 2011 - 06:14 PM
A puff of smoke on start up would tend to indicate valve stem seals, not so sure about the change up. What about on the over run and accelerating hard. If there is smoke then the oil control rings could be worn.
Doing the valve stem seals is the cheapest option, change them but at the same time have a look at the bores to see if there is any wear.
#4 Cerberus
Cerberus
  • 989 posts
Posted 24 August 2011 - 06:29 PM
Don't think there's any when accelerating or on the overrun.
My Dad, who was driving behind me today as we had to get two cars MOT'd, said he could see a puff of blue smoke when I changed gear.
Then, when the car was on the ramps, and it was started to be moved, I saw the puff of smoke, and then nothing, it was fine.
It does use a bit of oil, a lot less now I've sorted the majority of the leaks.
Just hope I don't end up spending money on the head when it comes off just because, 'its off so I might aswell', :D
oh and what's the test with doing a comp test, then putting oil down the bores and doing another comp test. I can't remember what the results indicate.
#5 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 August 2011 - 06:40 PM
Right if you do a wet test ie oil down the bores and the compression increases then its possible rings/ bore wear. If the compression does not increase then its valves.
Hopefully got that the right way round
#6 Midas Mk1
Midas Mk1
  • 5,777 posts
  • Local Club: S.U.N.M.C
Posted 24 August 2011 - 06:42 PM
I was getting blue smoke on full throttle, turned out to be the fuel pump leaking petrol into the oil.... >_<
#7 andy pandy
andy pandy
  • 270 posts
Posted 24 August 2011 - 06:50 PM
as sonikk said it one or the other rings or valves,but with midas mk 1 his oil was being thinned down with fuel, and oil would then bypass past the rings up into the combustion chamber.
#8 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 24 August 2011 - 06:54 PM
could check that the breathers are clear and that the engine isn't overfilled with oil
#9 andymini12
andymini12
  • 812 posts
Posted 24 August 2011 - 09:34 PM
I would change stem seals first and then see if it is still smoking as it is a lot easyer and a engine rebuild, but when my valve stem seals went it was blowing smoke inbetween gear changes.
