How Much Antifreeze Do I Put In
9 replies to this topic
#1 mohammed
mohammed
  • 433 posts
Posted 24 August 2011 - 03:22 PM
hi everyone
i know is many sound daft.. but it is important i gues.. i jst flushed the rad and engine and not need to refill with coolant.. how much antifreeze (eg 1 liter) is recommended to put in and how much water..
thanks
mohammed
#2 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 24 August 2011 - 03:25 PM
50/50 mix is a good start.
#3 jaydee
jaydee
  • 8,565 posts
Posted 24 August 2011 - 03:26 PM
Cooling sistem is around 3,5 l total
Antifreeze from 30% to 50%
Use distillated water and glycol-ethilene based antifreeze (its kinda blue stuff) because the modern organic-acid based coolants can damage your engine.
Edited by jaydee, 24 August 2011 - 03:27 PM.
#4 mohammed
mohammed
  • 433 posts
Posted 24 August 2011 - 03:29 PM
how much antifreeze will equal 50%.. is it a 1 liter bottle.. or more/ less
#5 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 24 August 2011 - 03:32 PM
Pour half the bottle into another container and refit with water = 50/50 mix.
Then when you have poured all the mix into the rad pour the leftover antifreeze back into the original bottle and fill with water - 50/50 mix.
Then top up as required. Any you have left over with be the right mix.
#6 jaydee
jaydee
  • 8,565 posts
I said it is 3,5l the entire sistem, so 50% = 1,75l
#7 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 24 August 2011 - 03:34 PM
He hasn't emptied the entire system !!
#8 mohammed
mohammed
  • 433 posts
Posted 24 August 2011 - 03:35 PM
thanks everyone
#9 bobs
bobs
  • 512 posts
  • Local Club: Six-Ex Mini Owners Club
Posted 24 August 2011 - 03:43 PM
Personally, and this is my view, you can never put too much antifreeze in...
#10 Big_Adam
Big_Adam
  • 7,435 posts
Posted 24 August 2011 - 04:32 PM
Aye, I just dump in a 1liter bottle, or just use that ready mixed coolant stuff if you're refilling.
