The Noobs Budget Vtec.
#361
Posted 27 August 2012 - 02:20 PM
#362
Posted 27 August 2012 - 10:09 PM
#363
Posted 28 August 2012 - 04:27 PM
Anyway - spotlight pod came today, along with the steel for my new alternator bracket... Will do a little bit of work tonight. Rear Valance was due to be here today, so I'm presuming that means tommorow as it wasn't here when I got home!
Also, away to fetch my front end and bonnet from Aberdeen tommorow - hefty old treck, but will be worth it! Then I'll measure up, make my alt. bracket, radiator bracket, get the valance welded on, and set about the wiring! Exciting stuff.
Then thursday, my boot lid is due - carbon fibre single skin - lovely! Time to order some paint I think!
#364
Posted 28 August 2012 - 04:37 PM
#365
Posted 28 August 2012 - 09:00 PM
#366
Posted 28 August 2012 - 10:27 PM
#367
Posted 28 August 2012 - 10:39 PM
#368
Posted 28 August 2012 - 11:51 PM
Will get pics of this up tommorow probably, save you searching back through!
#369
Posted 29 August 2012 - 09:15 PM
What engines it for buddy? Might be able to!
Its a B18 with a B16 head. Can't justify £80 for an Allspeed one when its just a few bits of metal!!!
#370
Posted 29 August 2012 - 09:30 PM
Its ok halfway down page 20 for me, my one was quite tight so I trimmed part of the plastic clip down, looking at it do you need all the green plastic (I know you like green!) but can you get away with heat shrinking some spade clips?
#371
Posted 29 August 2012 - 10:10 PM
Ahh, nah - I cant do the actual main part of the bracket I'm afraid - but I can get measurements and pictures so you can get a quote from local firms?
Yeah, I could probably do the spade idea - but looking at it now with the front end on I can afford to extend the top arm by an inch or two - which will help with routing wires away from the manifold!
I'll have a proper update tommorow - but for now...
#372
Posted 29 August 2012 - 10:23 PM
That is all
#373
Posted 29 August 2012 - 10:50 PM
#374
Posted 30 August 2012 - 04:39 PM
#375
Posted 30 August 2012 - 10:59 PM
Will be extended 90mm for now - will be going back to standard length after the next (top secret) stage of the project is complete...I can't remember what you said, (if you have) will you be using a standard length front end or extended?
looks beautiful mate :)
Cheers mate!
That is all
You'll be seeing her soon, dont worry ;)
