The Noobs Budget Vtec.
508 replies to this topic
#301 Jamie_hail
Jamie_hail
  • 555 posts
Posted 12 June 2012 - 12:57 AM
Always good to see the engine go I'n looks like you been working hard did you ring that guy i gave you the number for
Yeah - was a big releif! A years prep work payed off! Not yet buddy, gonna see if my loom works first!
Holy jeeeeesus mate thats some update! You've really cracked on :thumbsup:
I sold my complete b16 throttle body on and my current throttle body is aftermarket but I used the TPS off the type-r TB I bought as the aftermarket one didn't have one, so none here I'm afraid
Again I had a knock sensor with the type-r block but I didn't need it for my current one so I sold that on aswell >_<
Tie rods adjustments are a biaaatch-ass!
Love the alternator clip positioning, simple but effective!
I know you said you shimmed the engine position and its level and it might just be the pictures but the cam side still looks a tad high to me, I found this with mine, unless the rocker cover is precisely level with the head when tightened down on the gasket then its hard to take the reading from the top
Have a good look from the front, use the body lines (I know mini bodies aint renowned for there straightness!) use the frame lines etc go by eye
Cracking progress though, impressed, keep at it!
Aha Aye! Been pretty busy!
Ahh bugger, need both - but guess what? Cant find them anywhere! Even Tegiwa uk couldn't point me in the right direction!
I'm not looking forward to doing the alignment, hopefully the tie rods wont need touched, but that cant be guaranteed yet!
Was feeling a little bit inventive! Keeps the wires much tidier! But now I'm having problems with the other plug on the alternator clearing the manifold - dont know why it's an issue all of a sudden!
The cam side is about 5mm higher - measured and remeasured because I too thought it looked higher - wont have access to an engine crane for a few weeks now, so its going to have to do for the first start, but will be corrected before it goes on the road!
Thanks mate - having someone with your knowledge on here has been a BIG help! Cheers!
Wow, that was some serious progress, not far off first start now I bet?
Thanks mate - looking the next two weeks... Got the bores sprayed with a bit of plusgas, and turned it over by hand... Now just need oil, and fuel and cooling systems!
#302 Jamie_hail
Jamie_hail
  • 555 posts
Posted 12 June 2012 - 06:24 PM
More updates...
Worked a little bit on 'stance' - or in my eyes, road holding... Widened the track a fair bit! Added 1" spacers all round, and have 13x7's coming this weekend - so will be a good 2 inches wider!
As you'll see - she's a bit wider now, so should be a bit more positive on the road, and give the effect of lowering it about half an inch, without loosing practicality!
Now its close to first start, I've given the engine a bit of a makeover!
Quick once over with a can of engine enamel!
Also fitted the inlet manifold and got the fuel rail/injectors bolted in!
I got a thick 'thermal' gasket from Tegiwa to help keep intake temps down, looks a nice little peice of kit!
Before fitting my exhaust manifold, I replaced all the studs! No more mild steel. Gone from mild steel to stainless steel to compliment the manifold.
Tightened the drill chuck up on the old ones to get them out!
You can see I had a broken stud that I couldnt get out! Will work on it when I get some new drill bits!
I placed the rad in posistion just to make me think I was closer to being done! I'll treat myself to a new alu one when I can afford it - a lot of damaged fins on this one!
Looks a bit big? We'll have to posistion it properly when I get hoses and a front end!
A shot after the spacers were fitted... Looking nice and wide!
#303 Jamie_hail
Jamie_hail
  • 555 posts
Posted 12 June 2012 - 06:25 PM
Also! Got a mate down south working on a rocker cover for me! He is **** hot with an airbrush!
#304 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 12 June 2012 - 06:41 PM
Lovely build so far and I'm loving the rocker cover.
However please do not use those spacers you have bought! The ones that screw onto the existing studs are not safe they have been reports form people that sometimes the original studs have snapped under the extra load.!
#305 Jamie_hail
Jamie_hail
  • 555 posts
Posted 12 June 2012 - 10:30 PM
Oh no, dont worry stu! They're only temporary, they came from a friend with a ford focus, hence them being universal PCD. The spacings will be done with deep dish 13x8's eventually, just want the car ready for a shoot thats been booked first!
#306 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 14 June 2012 - 06:01 PM
Awesome thats cool!!!!
#307 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 14 June 2012 - 08:16 PM
Mate absolutely amazing project. Wish I had the time. I've got a '99 cooper with HIF44 conversion. She is my daily drive ATM so got to wait till winter for some work.
#308 Jamie_hail
Jamie_hail
  • 555 posts
Posted 19 June 2012 - 08:28 PM
13x7's are here and on - need a major refurb though! A lot more wiring and interior work done including making and fitting new headlinining - pics up later
Cheers - nice seeing some progress at last - its all coming together! Everybody has to do atleast one resto/conversion once in their lives! The bank balance and tears are well worth it!
Edited by Jamie_hail, 19 June 2012 - 08:30 PM.
#309 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 20 June 2012 - 06:51 PM
amen reverend! :lol:
#310 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 20 June 2012 - 10:57 PM
That rocker cover looks awesome!
#311 thelegg
thelegg
  • 608 posts
Posted 20 June 2012 - 10:59 PM
some may consider it a "mid life crisis"
#312 Rhys
Rhys
  • 898 posts
Posted 28 June 2012 - 09:27 PM
Over a week and no update! What is going on? Did you do a shoot in the end?
#313 Captain Mini
Captain Mini
  • 21 posts
  • Local Club: No idea?
Posted 01 July 2012 - 07:28 PM
I have to go change my trousers :P haha mate you have dont wonderful things with that car! Its really lush! Congrats buddy
#314 Rhys
Rhys
  • 898 posts
Posted 09 July 2012 - 05:12 PM
Come on, you must be done by now! :lol:
#315 coopdog
coopdog
  • 4,506 posts
Posted 14 July 2012 - 10:16 AM
nothing?
