The Noobs Budget Vtec.
#271
Posted 09 May 2012 - 11:36 PM
#272
Posted 10 May 2012 - 12:48 AM
Built it up with high build primer, smoothed the whole front end of the car, and painted. As can be seen in the next few photos.
First coat.
Started to poke around this rust in the rear end a bit more. Left (passenger) arch is perfect. The Drivers side is a bit worse for wear though!
Been soaking in kurust now for two days - Will then attack it with a flap wheel, see how bad it really is - Gave it a good prod, and nothing new gave way - so it may be salvageable for a year or so!
Cut the water bottle bracket off - as it wont be needed with the new layout in the car.
Gets hot in that boot while you're working!
All the old fuel lines are also out the boot now, and started to prod around to see what will need repaired. Cutting most the boot floor out for the carbon replacement. But this will need repaired. Right underneath the firewall. Shouldn't take much - only a 2" repair section.
As for the interior...
Big box of carpet arrived. I've cut a section to use for the headlining once everythings done.
Also carpeted the rear quarters
Parcel shelf, for mounting two of my speakers! Got to work on this!
Then carpeted the pillars.
Also, started to do some work on my dash again. I hate wiring, but we're getting there, slowly!
Few Savage switches in, along with the isolator, and toggles.
Glad to see things coming together, no matter how slow!
#273
Posted 10 May 2012 - 07:09 AM
Nice to see some progress and that you haven't been put off by the wait for the engine nuts
#274
Posted 10 May 2012 - 11:19 AM
#275
Posted 10 May 2012 - 12:07 PM
but yeh, either way, you worked around it haha
#276
Posted 10 May 2012 - 10:33 PM
#277
Posted 10 May 2012 - 10:39 PM
yep.. both wiper arms fell off. Wish mine were as welded on as yours haha
#278
Posted 11 May 2012 - 12:01 AM
I feel I jynxed myself from posting here yesterday... guess what happened earlier on the busy dual carriage way in pouring down rain
Haha, seriously? Gutted! How can they just, fall off? I even took a hub puller to mine, and made up a spacer to fit, and they wouldnt come off, even with my torque wrench maxing out!
#279
Posted 11 May 2012 - 01:22 AM
#280
Posted 16 May 2012 - 07:57 AM
#281
Posted 16 May 2012 - 09:38 PM
This wiring is driving me insane! Had to cut up my brand new loom to fit it through the bulkhead!
Can't see on the pics above but I take it you cut a hole in the bulkhead for the main loom and any other bits n bob you need to pass through
In which case why not just make the hole bigger, I mean you had to cut a hole in the first place right?
#282
Posted 17 May 2012 - 10:53 PM
Because, I'll still need to try and seal around the cable - cant find a grommet to fit either - so blanking off the holes I've made, and going to pass it through the passenger airvent instead, and pack it with sillicone!
#283
Posted 17 May 2012 - 10:58 PM
Doubt it but ... do you know Alan, tall bloke, from Fasfern Cottages?
#284
Posted 18 May 2012 - 01:47 PM
Off topic here, you're from Fort William? I LOVE that place so much, used to drive up every year from Kent...
I'm from a place near Fort William - Glenfinnan! And as I'm very involved with the estate, I know Alan Currie VERY Well! He's just married Fiona after nearly 7 years of engagement! You'll probably know Michael too?
#285
Posted 18 May 2012 - 02:05 PM
its scotland, everyone knows everyone up there
