The Noobs Budget Vtec.
508 replies to this topic
#196 Jamie_hail
Jamie_hail
  • 555 posts
Posted 26 February 2012 - 05:34 PM
Also - will someone please tell me what brake calipers I have? They seem like nothing available to purchase - everywhere has the 89-2000 cars down as two pot calipers on 8.4 disks. These are 8.4's, but they're alloy four pots? Need pistons, seals, and bolts for them!
Linky
Build's looking good mate, just don't get distracted by painting stuff ;D
Thank you! Perfect! Looks more and more like I got a bargain on this car every day! Only payed £800 for it, as a runner!
The painting just passes the time whilst I wait for parts! It's the attention to detail that makes a car anyway!
think your brakes are aftermarket mate they look like mini spares or mini sport brakes im prity shure they never made a mini with these brakes on them standerd but i could be rong
Minispares alloy four pots - minilandy was spot on! Thanks though! Your mini is coming on really well!
#197 Jamie_hail
Jamie_hail
  • 555 posts
Posted 28 February 2012 - 12:45 AM
Decided to sell a few of my shares, and transfer over some money from them to my regular account. Expect to see this mini done in the next month!
The budget hasnt changed atall, so expect this to remain on the same lines as before - I'm just using an alternative source of money to get it done sooner!
Did the deed and cut the bulkhead tonight!
Needs neatened up with a grinding disk and a file, but I'm pleased with that for an evenings work! :)
#198 Jamie_hail
Jamie_hail
  • 555 posts
Posted 28 February 2012 - 12:52 AM
That steels tougher than it looks! Having to cut at an angle doesnt help either.
#199 paul190181
paul190181
  • 193 posts
Posted 28 February 2012 - 09:57 PM
Your builds looking realy good . looking forward to seeing the end result
#200 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 01 March 2012 - 08:32 AM
Blimey, you cut enough out of that bulkhead! I don't think you need to go as wide as that, its more the height, see that bit at the bottom that tapers down between the clutch/brake holes for lhd/rhd thats the bit where it catches more
Make sure you mock up the engine and inlet in place before you go welding any box in
PM sent aswell
#201 Jamie_hail
Jamie_hail
  • 555 posts
Posted 01 March 2012 - 08:55 AM
Thanks! It certainly is a labour of love!
PM sent aswell
I decided to make the most of the steel i've ordered! I know it doesnt need to be quite so wide, but I'm a fan of nice clean engine bays, so the more space there is, the less I have to struggle! Thanks - I've taken that right down to the crossmember now - hopefully I wont have to cut any lower!
Yeah buddy! I should have the engine in place this weekend, depending how nice minispares are to me delivery wise!
#202 Jamie_hail
Jamie_hail
  • 555 posts
Posted 06 March 2012 - 09:43 PM
Busy few evenings! Progress, at last!
Minispares order arrived on Saturday morning, but was working all weekend, so started work on Monday evening!
Refurbed my steering rack first.. Had it apart, washed out the internals ect... Regreased, fitted new gators and the longer track rod ends, gave it a lick of primer, lick of paint, and a coat of stonechip.
Got it fitted back on the car :)
I need to get myself some nuts to go behind the track rod ends, but I've fitted them without for now just to keep the garage tidier!
The upper arms came from minisport a few months ago, got a rebuild kit to fit them, and new knuckle joints. Painted up my hi-lo's, and fitted my new suspension cones - so this should see me for a few years, all brand new parts! Nothing nicer than working with nice clean parts!
Apologies for this rubbish picture.
Then I went on to do my ball joints... I bought four of them to refurb my hubs - I need bearings, but they can wait for now... Searched the workshop high and low... Could I find a socket or spanner that would fit the cups on the ball joints? NOPE! So, I had to postpone that till tonight, my local garage let me borrow a 1.1/2 ring spanner... Does the job!
Spent an hour or so on them. Lapped in the new joints with grinding paste and a power drill... Cleaned out, shimmed, and greased... Sorted. Fitted nice new grease nipples too. Looks a bit messy in the picture, but a quick spray with brake cleaner has sorted it out nicely!
Went to do the other hub, did the bottom ball joint, no problems... Top ball joint was stuck solid, and also had a broken grease nipple. Plenty of heat and plusgas got the joint undone!
Managed to get a drill bit and stud extractor into the old grease nipple, as it was broken off flush! New nipple fitted, but can't get it shimmed up correctly on the joint, so will give it another go in the morning!
Saturday also brought a few other deliveries!
The alternator bracket from Kam, THANKS!
Got it fitted, need to give it a clean up and lick of paint, but I'll do that when the engines ready to go in! The engine needs painted again anyway, as it was never ran to cure the paint!
This also arrived!
I need to work on the centre console, as it is in completely the wrong place for my gearstick... Nothing too major... But the dash fits perfectly!
Had the dash in to have a lick of paint, I'll do the centre console when I've decided how the sticks going to come through!
First coat.
Final product. Nice matt black finish to reduce glare. Going to use some nice big analogue dials. For fuel, tach and speedo. I will use some small black gauges for oil pressure, oil temp, water temp, voltmeter, AFR, and vaccuum. These will be fitted in the centre console area.
I love seeing progress. I've striked a deal with ABS for my front end - bit of discount for having it stickered up in their graphics!
Just need tie bars, and bottom arms, and she'll be ready to drop the block in! My sheets of steel arrived today too!
#203 Jamie_hail
Jamie_hail
  • 555 posts
Posted 06 March 2012 - 09:45 PM
Oh, and I fitted a second drop bracket. What a lovely angle on the steering column. Will feel gorgeous to drive!
#204 KieranB
KieranB
  • 360 posts
  • Local Club: S.U.N.M.C
Posted 07 March 2012 - 08:21 AM
Loving the work you're doing, im starting my vtec project at the moment but its very slow so watching yours very closely. Been good help so far
Keep up the good work :)
#205 Jamie_hail
Jamie_hail
  • 555 posts
Posted 07 March 2012 - 04:05 PM
Thanks Kieran! Good luck - my progress has been slow due to money problems, but if you know what you're doing, you can fly through it all! This is the first time I've touched a car properly, and I manage!
Thanks again!
#206 KieranB
KieranB
  • 360 posts
Posted 07 March 2012 - 04:42 PM
aye im in the same situation plus working full time and doing my first house up so its all a bit much at the moment. but its always nice to find a little time where you can go and work on the car.
Next time im up home i might have to take a trip over to fort william. My folks are at Tayside if you know where that is.
#207 Jamie_hail
Jamie_hail
  • 555 posts
Posted 07 March 2012 - 05:31 PM
Exactly! Keeps it exciting though... If I weren't having to wait for parts, wait for money - it be like putting together flat pack furniture - boring!
Yeah buddy - Or I'd come for a spin in your direction. Tayside isn't too far, go down there with work for 'corporate events' - AKA... A spot of fishing!
#208 KieranB
KieranB
  • 360 posts
Posted 07 March 2012 - 09:13 PM
haha i like your confidence, whats your next step in the build? close to getting engine in?
Ye its not far at all, good wee blast through glen coe and your almost there. my dads work is in Killin, (A & B Services steel fabricators). if you ever need anything doing im sure i can get it done for cheap :)
#209 Jamie_hail
Jamie_hail
  • 555 posts
Posted 08 March 2012 - 12:50 AM
Need to keep myself going somehow! Yup - Get some tie bars on, then pop the engine in! Then driveshafts, a front end, and paint!
Aye, and in this thing, it'll be a fun wee blast!
Thanks, thats always handy to know! I've been into fabricating since I was 14, but if I need anything decent knocking up, I'll be in touch! I ride trials, so I'm in Killin every couple of months for competitions!
#210 Jamie_hail
Jamie_hail
  • 555 posts
Posted 08 March 2012 - 10:43 PM
So - Painted those hubs today... Coat of etch primer, then two of matt black. Looking good if I may say so!
Excuse the dust, I got happy with the angle grinder a few hours afterwards!
This had rusted through in my wing, and left me with a hole where the wire brush eat away at it!
Cut it out. Not the neatest job, but it'll do...
Cut a new peice to fit - I spent an extra half hour getting it to be a perfect fit in the hole, after this picture.. Which it was! Welded it in, and ground down the weld. Looks good - will get pictures up tommorow!
Also painted my parcel shelf, and around the rear window... Zinc primed, then painted.
Again, not the best job in the world, but it'll do until I go for the whole respray!
Edited by Jamie_hail, 08 March 2012 - 10:43 PM.
