I've posted this in my project thread, but no doubt there is more traffic here so more chance of an answer.
Over the past couple of months I have changed both the timing gasket/crank seal, selector seals, and the headgasket, aiming to get rid of my oil leak(s). I noticed it was leaking again after a couple of long drives, and I assumed from the timing cover again, so I cleaned the engine.
Clean sump by bcjamesmini, on Flickr
Then this morning I went for a drive up the M1, about 30 miles, to make sure I could get it to re-leak. Worked a treat, although didn't give the result I wanted!
All good here by bcjamesmini, on Flickr
So, clearly the oil dripping off of the engine around the timing cover/diff is in fact originating from further up. All of the front of the engine (as viewed) is clean, right down to the middle of the sump. The oil is pooling and dripping off the sump from down the back of the engine.
Not so good here... by bcjamesmini, on Flickr
Although the photo is not great, you can see the wet path of fresh oil going down the otherwise matte block behind cylinder 1, on the very corner. The head gasket was changed about a fortnight back, since it had been leaking from here. I thought it had been fine since, but the oil must have just been getting lost amongst the muck.
Does this mean something is wrong with the head? I am losing quite a bit of oil out of it! Thankfully I have MRA up the road who can sort pesky cylinder heads, but I'd like an idea of whats happened before it comes off the road again!
Learned folk of TMF, educate me!
