i checked all the ignition related stuff, the head was skimmed before it was refitted, i have no idea why it blew. i hope it isnt the rings, the bores were fine when i took the head off (all pistons were in the center of the cylinders) how would i check the rings without removing them.
Firing Order
#31
Posted 05 April 2016 - 06:38 PM
#32
Posted 05 April 2016 - 08:00 PM
I would like to suggest that you start a new thread more focused on the problem you are dealing with. This thread was started years ago with a title focusing on the firing order which is not the issue you are dealing with. A new thread with a new title may get fresh eyes looking at your car's problem.
As for checking the rings, that is typically done by making a new set of compression readings. Ideally the engine would be warm but with a non-runner you do the test cold. Make sure the throttle is held wide open. After the compression test, remove the spark plugs and one at a time tip a table spoon of motor oil in through the spark plug hole. Repeat the compression test. Compare the "dry" and "wet" test readings for each cylinder. If you see a temporary and significant rise in the compression figures with oil, you have blow by issues associate with worn rings and bores.
An alternative to the compression test is to do a leak down test. That requires that you have a leak down gauge and a source of compressed air. If you don't already have a leak down tester you may be able to find someone who can help you carry out the tests and explain the outcome.
#33
Posted 05 April 2016 - 09:08 PM
i will start a new thread. i have tried the oil test before and it made no difference. thanks anyway
