Thanks! The simple answer to your question is that I don't know as I have not done it and I wouldn't want to just make up some random answer.sounds like your mag is the kinda mag I like then! :wink:
all techy, with proper tech advice! (not bloody telling you to sink your valves into the head - like a certain someone did, in a certain mag)
as a sort of related Q, what sort of power would you expect a LONG stroke engine to make, before it starts ripping the conrods apart?
for example, a 1098, with a 12g940 head. Would you expect it to cope with 100+Bhp's worth of boost?
more curious as to anything else really
I do know that my friend Jai of Minicranks in New Zealand turns these engines nat asp to 7k rpm with no problems. After that, they start eating bearings.
With such a long stroke, I doubt you would actually get the engine to the sort of HP/rpm levels where what I am talking about comes into effect. Again, it's not boost pressure that is the problem, it's rpm. The 1098 is almost self limiting in that respect.
Don't think I am saying anything other than a short stroke engine is rubbish, I'm not, there are lots of 13 second 1293's, I'm just stating the theoritical advantages of them, which I am testing myself with this engine build which I hope will go beyond the power produced before by some considerable margin
I should stress again, it's not boost that kills engines. Forced induction, (and I include nitrous oxide injection in this definition as well, it is just a chemical supercharger), also helps to reduce the tensile loads the engine sees at BDC as the vastly increased volumes of exhaust gas cusions the piston as it goes over BDC, with some extremely trick electronics I hope to be able to quantify this effect.
Sorry I can't answer your question further but at least that's an honest answer! Why not try one?!
