10/40 Oil Will It Affect My Mini ?
Posted 17 August 2011 - 12:24 PM
Posted 17 August 2011 - 12:37 PM
asking topics on oil always cause issues on this place. minis have been around for so long everyone has an opinion on what oil is best.
it might be worth searching and drawing your own conclusions.
Posted 17 August 2011 - 12:45 PM
Posted 17 August 2011 - 12:49 PM
Posted 17 August 2011 - 12:52 PM
+1 most agree that thicker oil is better due it being shared by the gearbox and engine.I'd stick with 20/50.
Posted 17 August 2011 - 01:05 PM
Posted 17 August 2011 - 01:13 PM
Posted 17 August 2011 - 01:19 PM
What you must do, with whatever oil you decide to use, is change it regularly.
Posted 17 August 2011 - 01:29 PM
i think 10/40 is more better for slighty worn engines thats what iv been told anyways
I'd actually say 20W/50 is better for a worn A-Series, as it's ticker.
I've had both 10W/40 and 20W/50 in my last Mini and the 20W/50 was far better, it ran better and the gear change was smoother.
Posted 17 August 2011 - 05:45 PM
I had the opposite. I run 10w40 because its much smoother over 20w50
Posted 17 August 2011 - 05:50 PM
I know that Minis ran off the productionline with 10W40 in their bellies, so that's what the manual says.
Believe me, I've tried a fair share of different oils over the years, and my personnal opinion is:
20W50 keeps the oilpressure slightly higher, makes the engine somewhat quieter and makes shifting gears easier.
It also reduces oilburn and leaks.
That said, there's no problem using the recommended 10W40 in an old Mini, but keep an eye on your oilpressuregauge..
Edited by yellowmonster, 17 August 2011 - 06:13 PM.
Posted 17 August 2011 - 05:57 PM
Posted 17 August 2011 - 06:46 PM
It's the gearbox which suffers with thin or synthetic oils as it shares the engine oil. Ideally the gearbox would have an EP80 gear oil, so even 20w50 is a bit thin for the 'box.
Posted 17 August 2011 - 07:04 PM
Your thinner 10w40 is also probably a synthetic or semi-synthetic and that's not as good as a mineral oil.
This is quite a simplistic view as synthetics are superior to mineral oils in most respects.
What you mean to say is use a higher viscosity oil, which tend to be mineral oils!
Posted 17 August 2011 - 07:14 PM
Synthetics are superior to mineral oils in applications designed for synthetics and I would never use anything else in my BMW 325i. Minis were never designed for synthetics though. I once tried a top quality synthetic which an oil company gave me for rallying. I used it on one event, then had to spend almost £1000 rebuilding the gearbox and engine as, at up to 7400 rpm, the main bearings, syncros and cam bearings all went 'up the pictures', so I do think I speak from expensive experience.
I discussed this with a really experienced senior engine design specialist who worked for Cosworth at the time and with whom I did a lot of business. His comment was "If you run an old A-Series engine & box on 'weasel p**s', what do you expect". He explained the need for a thicker minerqal oil and recommended an oil called Kendall 20w50 which was made from Pennsylvania crude oil. That is NLA in the UK, so I always use valvoline 20w50 in the rally Minis and Castrol Classic 20w50 in the Mini road cars.
Sorry if it seems simplistic, but it's a simple answer which is needed here really.
