Whats The Best Performance Exhaust To Get For A 1275 Engine
Posted 16 August 2011 - 09:36 AM
Right, so i've been looking at all sorts of different exhausts recently, as I have a standard setup with a cat. And from what I can work out a 1.75" diameter will give the optimum power, but I read that about the 998 engine, would it be the same for the 1275 or should I go slightly bigger?
Also which manifold to go for, as I have seen some mixed opinions whether a LCB is better or the rc40 one on a 1275. I know maniflow is the best, but a little too pricey for me at the minute.
Is a centre exit single box the one to go for, or is a twin box side exit better?
Sorry for all the questions.
Cheers,
Adam.
Posted 16 August 2011 - 04:15 PM
Posted 16 August 2011 - 04:28 PM
Posted 16 August 2011 - 06:53 PM
I used to have a cooper freeflow but changed to an Maniflow LCB, I think I lost some torque in the process so not sure it was worth it, had a single box RC40 which was noisy so added the centre box, made it quieter and got some torque back too. Side or centre exit wont make a difference.
100% correct, and 1.75" internal diameter is the ideal size.
Posted 17 August 2011 - 09:08 PM
Posted 17 August 2011 - 10:09 PM
Would a full 2" maniflow system be too big?
Yes, a bit too big unless you are going to bore to around 1380 and use 7000 rpm.
For a 1275 to 1330 cc engine using up to about 7000 rpm, a 1.75" is best as it gives the optimum gas velocity down the pipe.
Posted 17 August 2011 - 10:36 PM
Posted 18 August 2011 - 10:56 AM
Is the 1.75" the internal diameter? As the guy selling the maniflow has said that he measured the backbox pipe external, and it was around 2"
Posted 18 August 2011 - 11:46 AM
And yes a 1.75" is what you need, its also what you get with the 1275 stage kits
Posted 18 August 2011 - 11:49 AM
Posted 24 August 2011 - 03:59 PM
