#76
Posted 17 January 2012 - 08:35 PM
#77
Posted 17 January 2012 - 08:39 PM
Check most project pages pal - unless you're a small celebrity in these parts, it's pretty much your personal diary. Don't demand attention, you'll shun the viewers.
In any case, what you've done so far is great work. Can't wait to see the engine in good order - any mods to the gearbox?
Thanks for the advice, And the gear box is compleley standard
nice when you rekon it will be finished? and also what did you clean your subframes with and what paint did you use as im at this stage now on my project thanks tom
The deadline is May as that is when im learning to drive. I cleaned my subframe with a wire brush on my angle grinder and painted with a few layers of etch and then a few layers of Black hammerite
#78
Posted 17 January 2012 - 09:04 PM
#79
Posted 17 January 2012 - 09:15 PM
#80
Posted 17 January 2012 - 09:18 PM
looking good, good that another mini 30 will be on the road
Yeah I can't wait for it to be on the road
#81
Posted 18 January 2012 - 05:55 PM
Once i have the 205 back on the road my next project will be a Mini to work on with my 13 year old son so it is interesting to see how you go about it!!!!
Be careful using hammerite on cars as it does not flex well and can end up letting water get under it which will cause rust.
#82
Posted 18 January 2012 - 05:58 PM
Just read the full story so far, great work.
Thanks for the interest,
I'll take the hammerite tip in mind
#83
Posted 18 January 2012 - 10:31 PM
Ok, how did u stick the core plugs in, sealant, blue hymolar??
Told you, lol!
Graham
#84
Posted 18 January 2012 - 11:50 PM
Nice work, as said before lots will read but few comment. That's how it goes but don't stop.putting the pics up as when someone sees something they don't get, they comment.
Told you, lol!
Graham
Yeah i used sealant and a socket as a drift and they went in no problem. Look the buisness to
#85
Posted 21 January 2012 - 01:36 PM
There should be a decent update tonight
#86
Posted 21 January 2012 - 06:07 PM
Petrol tank in a layer of Etch -
Servo painted and rebuilt -
New scuttle end welded in. Its not finished yet as i still have more grinding and filler to go on.
There should be another update tomorrow eveing so check back then more more progress.
All opinions welcome
Andrew
#87
Posted 21 January 2012 - 07:42 PM
All the best
Hugh
#88
Posted 21 January 2012 - 09:02 PM
#89
Posted 22 January 2012 - 05:04 PM
Mostly boring body work today but it has to be done
All went well apart from a small fire :/ and cutting half way through the engine loom with a angle grinder but its all good now.
Any way PICS -
Patch welded in on the inner wing ( Not ground down yet )
Got my moneys worth out of this one -
Very messy pantch wleded in just bove the jacking point ( Needes to be tidied up more so dont judge me )
I also repaired the hole that was in my rear arch but forgot to take a photo so will get a pic up next time.
Im now getting ever closer to putting the front end on its just a matter of finishing the inner wings.
More updates very soon
All opions VERY welcome
Andrew.
#90
Posted 22 January 2012 - 08:08 PM
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
