#661
Posted 06 January 2013 - 02:32 PM
#662
Posted 06 January 2013 - 03:21 PM
Andrew.
#663
Posted 06 January 2013 - 03:57 PM
First of we demasked the car and there is no other word for it ! The roof if just porn -
Then we masked her up ready for spraying the drivers side and the rear -
And then there was nothing for it but to start painting and it looks smashing
Then i made a little mistake with the lacquer on the A Panel, This will be flatted back and re done tomorrow -
That's todays work done, The forecast looks good again for tomorrow so i should have all the spraying finished by then
That means ill get to demask the car and pull it out into the light. Very excited
Please let me know what you think
Thanks again
Andrew.
#664
Posted 06 January 2013 - 04:01 PM
Could I bring mine down to you in a couple of years haha?!
#665
Posted 06 January 2013 - 04:04 PM
If you'd trust me to spray it for you then yes, Go for it !
Andrew.
#666
Posted 06 January 2013 - 04:05 PM
#667
Posted 06 January 2013 - 04:12 PM
Andrew
#668
Posted 06 January 2013 - 04:16 PM
#669
Posted 06 January 2013 - 04:24 PM
Andrew
#670
Posted 06 January 2013 - 05:04 PM
#671
Posted 06 January 2013 - 05:16 PM
#672
#673
Posted 06 January 2013 - 05:22 PM
Minidarren83 - Thats very nice of you :') It is my first time doing a full respray myself however I do work part time in a spray shop and have consequltley picked up a good amount of experience. You can't really go that wrong spraying white, It's a very nice colour to hide the imperfections.
I used a 2.0mm HVLP gun for the High Build primer, a 1.4mm HVLP for the base coat and a 1.3mm HVLP for the clear coat.
And my advice would be get the prep right, Spend as much time as you need sanding and flating, If you get the prep right then the spraying is the easy fun bit
Andrew.
#674
Posted 06 January 2013 - 06:40 PM
Keep up the good work
#675
Posted 06 January 2013 - 07:02 PM
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
