Mini Thirty 998 Project
roundnose
919 replies to this topic
#46 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 30 September 2011 - 06:34 PM
Bump
#47 FARRANTINO
FARRANTINO
  • 163 posts
  • Local Club: Bucks Mini Club
Posted 30 September 2011 - 06:40 PM
good work fella
#48 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 30 September 2011 - 06:47 PM
Cut the rust out, don't plate over it or you will end up doing it again later. I've just done the same sort of job on Project Paddy so have a look on there if you need some tips etc.
Also you don't need to keep bumping your thread, people will still look at it without making comments. You will be surprised at how many people will look at a thread without saying anything. Keep posting away as most of us like to see how other members get on with their projects.
#49 Bash Master
Bash Master
  • 150 posts
Posted 30 September 2011 - 08:03 PM
Subframe is looking great :thumbsup:
#50 Andrew O
Andrew O
  • 1,425 posts
Posted 30 September 2011 - 08:17 PM
#51 Andrew O
Andrew O
  • 1,425 posts
Posted 03 October 2011 - 04:13 PM
Well i had an inset day on Friday and Monday which meant an extra long weekend and as i wansnt doing Motocross it was Mini 4 days in a row :D
Here come the pictures -
My top arm bearings arrived on Saturday which meant i could get the cones in . And ow my God it was sooo difficult ( Considering i have never done it before )
My dad even high fived me when we finished and that is saying something as he hardly talks to me Hehe
There were 3 tiny holes in the boot that i have never noticed so i welded them up
Before -
After -
I have been practising my welding lots so i thought i would takle the shock mount areas
Before -
After -
What do you think ???????????????
For my first ever weld job ( Im 16 ) its not bad going
My dad helping me out -
There was a hole on the inside so i patched that up. I know its not perfect but it does the job and you won't see it.
Painting my Cylinder Head -
Im also in the process of removing the sound proofing ( The tar like stuff ) but I'm not finished yet, I will get a photo up when its done.
Well thats about it for today
Please add your comments tips or opinions as i would REALLY appreciate them weather good or bad.
Watch this space for regular updates.
Thanks.... Andrew
#52 grahama
grahama
  • 2,442 posts
Posted 03 October 2011 - 04:38 PM
Hi,
love the subframe work, hope mine look as nice when I do them this Winter. I would however have another look at the patch you have welded in. Personally I would grind them down alot and at the very least go over them, maybe with a little more power or less wire speed to join everything up and seal the gaps/pinholes you have. If there is a place for water to get in, it will.
Not critisising but you don't want to have to re-do them in a year. Hopefully someone with lots more welding experience will comment on the patch to help you. It's all a big learning curve so keep going and keep the pics coming.
Graham
#53 Andrew O
Andrew O
  • 1,425 posts
Posted 03 October 2011 - 04:44 PM
Hi,
Graham
Thanks for your advice ( Much appreciated ). I forgot to add in that i hadn't grinded down the weld you are referring to so its not complete yet, But i see what your getting at with the holes and i will have to address that.
Thanks very much ... Andrew
Ps Your project is looking great
#54 jaydee
jaydee
  • 8,565 posts
Posted 04 October 2011 - 11:05 AM
The weldings look fine, i would just fill all the little holes and imperfections a little better then carefully file down a bit on the damper mounting holes just to make sure that once you've fitted the daper mountings, they will sit straight.
On the cylinder head, are you going to skim down the top surface? if not, remove the paint on the surfaces where the nuts will be torqued..
Good luck! :)
#55 Andrew O
Andrew O
  • 1,425 posts
Posted 04 October 2011 - 11:25 AM
Good luck! :)
Thanks for the comments, Once i have ground down the welds i will go back over them filling in the holes. And i will be rubbing the paint of the mating surface.
#56 holmesy
holmesy
  • 879 posts
Posted 07 October 2011 - 02:29 PM
hey sorry i took my time to reply, college got me going lke crazy so the mini been left for a month but yours looks like its coming along well now :D , sprayed the roof white and am quite please for my first paint job as i only ot 1 small run so im a happy bunny, went to snetterton last weekend and a very nice mini pulled up along side of me and after having a butchers it turnt out to GEOFF MABBS 1963 morris cooper s type!! as i sat in it looked up and saw that Pady Hopkirk had signed the sun visor and everything was orginal!! as you said about making a thread ofmy build i will have a go when i get my latop back ad upload the pics of what ive done, good luck
#57 mk1leg
mk1leg
  • 9,343 posts
Posted 07 October 2011 - 07:40 PM
coming along nicely..........keep it up.................. :proud:
#58 Andrew O
Andrew O
  • 1,425 posts
Posted 07 October 2011 - 08:29 PM
Thanks, Stay tuned there will be an update in the next few days
#59 Andrew O
Andrew O
  • 1,425 posts
Posted 22 October 2011 - 04:22 PM
Right i havnt updated in while ( Too busy with Motocross,School and working on the Mini ) so this one is a BIGGY
Ive got a week off school next week so i will hopefully be finishing the welding thats all weather dependant though.
Here we go .... Lots of pictures
Welded the new inner wing part on and cut the scuttle ready for new peace -
Dad offering up the new piece -
Hole in the roof all sorted -
Rear valence cut off -
Any ideas what i should do about this???? ( Its the rear arch )
Closing panels will have to be replaced -
Discovered a new hole when taking the subframe out -
Second roof hole sorted ( Not sanded smooth yet ) -
Few bits from Ebay -
Scuttle sorted out -
Underneath -
Sound proofing out -
Headlining out to check the roof ( Found many spiders in the process ) -
Footwell patched up -
Shock mounts sorted out -
Well don't say i didn't warn you it was a big one :D ( Sorry admin team )
Stay tuned as there will be a lot of progress in the next week
As always PLEASE ADD YOUR COMMENTS AND OPINIONS
Thanks again Andrew.
Edited by Andrewo330, 22 October 2011 - 04:23 PM.
#60 holmesy
holmesy
  • 879 posts
Posted 27 October 2011 - 02:14 PM
looking good :)
