yes mate demon tweeks is painting itI thought it was with Demon Tweeks for paint ?
#421
Posted 31 May 2012 - 07:29 PM
#422
Posted 31 May 2012 - 08:51 PM
#423
Posted 01 June 2012 - 07:15 AM
#424
Posted 01 June 2012 - 10:06 AM
Yes for the hubs etc I use a knotted wheel on the angle grinder and it brought them up a treat.
All it took was time getting every bit of rust off and then giving them a good coat of paint.
Andrew.
#425
Posted 01 June 2012 - 10:36 AM
Got a good amount done today, Im almost ready to fire here up
Pictures -
Fuel pump on with some sexy braided fuel line ( Not that you will see it anyway ) -
Three way junction hooked up -
Braided front hoses arrived -
Stage 1 Inlet and Exhaust manifold fitted -
New heater valve hooked up -
Radiator and alternator all connected -
New Lucas coil -
New oil filter is a must -
Brand new starter motor -
As she stands at the moment, Just got the carb to fit -
New closing panel welded on -
I now need to weld the other closing panel on and then finish de bumpering the valence.
Once this is done i can put the rear sub frame on, put the fuel tank in and then fire her up
All comments are very welcome as usual
Andrew.
some cracking work on this mate
#426
Posted 01 June 2012 - 11:34 AM
#427
Posted 01 June 2012 - 01:23 PM
Thanks mate. Im liking your alloys by the wayYeah I got them from eBay, I'll find a link for you
#428
Posted 01 June 2012 - 01:45 PM
#429
Posted 01 June 2012 - 03:24 PM
Andrew
#430
Posted 01 June 2012 - 03:37 PM
#431
Posted 01 June 2012 - 03:40 PM
I also have a Mini Thirty.. Have to admit yours will look better than mine when finished i expect ;)
#432
Posted 01 June 2012 - 03:56 PM
I hope it will look nice but I am spraying it myself so it could go horribly wrong.
Andrew.
#433
Posted 01 June 2012 - 05:32 PM
bit of advice make sure u know where everything goes before you take a part, take a pic before aswell incase you forget hahahaThank you very much.
Andrew.
#435
Posted 01 June 2012 - 05:36 PM
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
