#346
Posted 14 May 2012 - 11:45 PM
#347
Posted 15 May 2012 - 07:25 AM
#348
Posted 15 May 2012 - 07:26 AM
#349
Posted 15 May 2012 - 10:57 AM
That is a point I did think off, but I can't really lay the silent coat on the bulk head as there are two many different surfaces and wires all over the place
if you bundel the wires together, and have 1 or 2 entry holes/grommets they pass though, that's where you can make a small hole in the silent coat, anyhow that is up to you off course.
#350
Posted 15 May 2012 - 07:38 PM
Once i have everything working i will look into it then.
Any way update time
Managed to get some smaller things done in between revision.
Pictures -
Wasted more money on DSN classics parts
But they look sooooo good -
Got the fuel line connected with an inline filter -
K and N air filter fitted -
New break cap thingy -
Petrol tank fitted and connected -
And i even had a little helper -
Would love to hear your thoughts as usual.
Andrew.
#351
Posted 15 May 2012 - 08:06 PM
#352
Posted 15 May 2012 - 08:24 PM
Still got more DSN parts to go on
#353
Posted 15 May 2012 - 08:29 PM
#354
Posted 15 May 2012 - 08:36 PM
#355
Posted 15 May 2012 - 08:42 PM
Yeah I will be doing the bonnet to
You can stick it inside the bonnet? Is the glue heat resistant?
#356
Posted 15 May 2012 - 08:43 PM
Spray glue isn't, but most contact adhesives are. That's spoken from experience after mine fell off.
#357
Posted 15 May 2012 - 08:46 PM
#358
#359
Posted 15 May 2012 - 08:49 PM
I mean the adhesive that comes on the back of the silent coat already. To fit silent coat you dont need to buy any additional adhesives as it is already there.
Edited by fattail95, 15 May 2012 - 09:05 PM.
#360
Posted 15 May 2012 - 08:51 PM
I mean the adhesive that comes on the back of the silent coat already. To fit silent glue you dont need to buy any additional adhesives as it is already there.
Yes, don't mind me, was thinking of the stuff I stuck over the silent coat.
Yes, it is OK to go under the bonnet:
It can be installed anywhere in your vehicle including under the bonnet.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
