#286
Posted 10 April 2012 - 08:23 PM
#287
Posted 10 April 2012 - 08:53 PM
#288
Posted 10 April 2012 - 08:54 PM
#289
Posted 10 April 2012 - 08:58 PM
#290
Posted 11 April 2012 - 12:50 PM
#291
Posted 11 April 2012 - 01:17 PM
#292
Posted 11 April 2012 - 07:46 PM
Just interested to see how you're going to fit your seats! Are you making your own frames or are you just going adapt the ones they came with?
So am i haha, I think were going to buy standard Mini ones and weld them on under neath.
Looking good buddy
Thanks very much, There will be a new update in 5 Mins ones photobucket has finished uploading
#293
Posted 11 April 2012 - 08:00 PM
Pictures -
Subframe partially built back up with all new pipes -
Heel board and boot floor now have a nice coat of chassis black -
Arch in underseal -
And the front arch -
Thermostat housing on and the fan -
Attached the servo and connected it all up -
Sprayed the filter housing -
How shes standing now -
Tacked the first closing pannel on -
Thats about it car wise for now, However -
I ordered a 2 Meter role of real suede as i had something pretty cool in mind. Ive always likes how some luxury cars have suede dash boards and dash rails so i thought why not do it with mine, So here are my results -
I covered up the ashtray hole as i wont be using that -
The photos really do not do them justice. They just feel and look so good and it only took me 2 Hours and cost me around £40 for material and glue etc.
I would love to know what you all think after this rather sizable update .
Andrew.
#294
Posted 11 April 2012 - 09:22 PM
#295
Posted 11 April 2012 - 09:41 PM
#296
Posted 12 April 2012 - 11:39 AM
#297
Posted 12 April 2012 - 12:03 PM
#298
Posted 12 April 2012 - 06:59 PM
Heres a before and after of my hub . Im really please considering how bad it was
Before -
After -
Just read the project from start to finish, doing a great job. The engine and subframes look mint
Just a little point, did you tap over the tab washer on the front ball joints as in the pictures it doesn't look as though you have.
(Could be wrong just checking )
I'll keep watching this one.
#299
Posted 12 April 2012 - 07:30 PM
The tabs have not been done yet as I have not finished shimming them up, So yes you were right
Good spot ;)
Andrew.
#300
Posted 13 April 2012 - 09:10 PM
Pictures -
Fuel pump on with some sexy braided fuel line ( Not that you will see it anyway ) -
Three way junction hooked up -
Braided front hoses arrived -
Stage 1 Inlet and Exhaust manifold fitted -
New heater valve hooked up -
Radiator and alternator all connected -
New Lucas coil -
New oil filter is a must -
Brand new starter motor -
As she stands at the moment, Just got the carb to fit -
New closing panel welded on -
I now need to weld the other closing panel on and then finish de bumpering the valence.
Once this is done i can put the rear sub frame on, put the fuel tank in and then fire her up
All comments are very welcome as usual
Andrew.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
