I also took delivery of my polyurethane bushes and Front Gaz shocks
I would really appreciate peoples thoughts i my project and if you have any advice please share them
That is if any one is actually reading this
Thanks..... Andrew
Well Andrew, you're putting some effort and nice attention to details but i want to give some advice about some points..
You need longer bolts to fit those thick poly mounts..
.. and dont want to be pedantic, but my advice is strongly against any poly floor mountings and poly front teardrops..
I had them in the rally car, all properly fitted with longer bolts, and i found them:
- too flexible
- a pain to fit/replace
- they make an annoying and embarassing SQEEEK noise when car is driven hard
- the poly front teardrops lasted about 10 miles, then became too flexible and useless, the poly bushes for the engine steady lasted for about 20 miles..
I wouldnt bother on poly engine mounts neither..
Also painting the mating surfaces on the drive flange should not be painted, the surface have to be clean and spotless otherwise wont seal properly on either the disc and the wheel. You may have juddering issues especially under braking as a result.
And the hub, be carefull to not paint the inside where the bearings will fit. Clean the internal thoroughly and check for marking/scorings before greasing and fitting the bearings outer races.
Good luck with the rebuild, adn those GAZ dampers are really a nice bit of a kit
Edited by jaydee, 01 September 2011 - 09:26 PM.
